[Solved] Air Conditioning Fan Troubleshooting in VW Passat B5 130 km - Replaced Brushes, Fuses, and Relays
janek ie 15924 16
How can I test why the first speed of the VW Passat B5 air-conditioning fan does not turn on when the second speed works, after replacing the brushes and checking fuses, relays, and the pressure sensor?
The first fan speed is controlled by the resistor pack under the left side member, and you can test it with a 12V bulb or meter at its three pins with the engine and A/C on [#16536628][#16536740] If voltage readings are abnormal there, the resistor pack is the likely fault; one user reported only about 4.6 V on the outputs instead of 12 V [#16536841] In the end, replacing the resistance bar under the longitudinal member fixed the problem [#17406647]
  • #1 16536472
    janek ie
    Help: 8
    Rate: 17
    Hello, I have a problem with the air conditioning fan in vw passat b5 130 km. I have already replaced the brushes, I checked the fuses and the relays, everything is ok, the pressure sensor also works. The only thing I can't check is the defender, my question is whether you can bypass the resistors to check if the fan turns on in the first gear, because the second gear also switches on ok please help thank you
  • #2 16536581
    jdubowski
    Tube devices specialist
    Help: 2511
    Rate: 2795
    janek ie wrote:
    The only thing I can't check is the paddler
    Ohmmeter is not working?
  • #3 16536616
    janek ie
    Help: 8
    Rate: 17
    hello I am a beginner mechanic where it is and how to check it
    domex32
    Help: 585
    Rate: 2450
    On the left side member, underneath, check with a 12V bulb whether it is lit on all pins when the fan will not work, with the engine on and the air conditioning on.
    You have three pins with 10mm nuts so look for tension.
  • #5 16536640
    janek ie
    Help: 8
    Rate: 17
    I checked this cube, the meter in one is 13.5 volts constant and on the other I have a tremendous voltage, once it is 13.5 vol, 2 vols, then 8 vol and I still jump
  • #6 16536651
    domex32
    Help: 585
    Rate: 2450
    I do not know what are you writing about.
    This is a resistance.
  • #7 16536666
    janek ie
    Help: 8
    Rate: 17
    I have a resistance from the lake or something, this is not the resistance that you sent a photo
  • #8 16536678
    domex32
    Help: 585
    Rate: 2450
    So it turns out that you write about the supply fan yes? To the cabin.
  • #9 16536690
    janek ie
    Help: 8
    Rate: 17
    then maybe write me what turns on the air conditioning fan in gear 1 because they write that it is the lake resident
  • #10 16536709
    domex32
    Help: 585
    Rate: 2450
    Which fan, under the hood or in the cabin, WHAT ARE YOU ABOUT ??
  • #11 16536714
    janek ie
    Help: 8
    Rate: 17
    under the small mask
  • #12 16536716
    domex32
    Help: 585
    Rate: 2450
    Where do you have the hedgehog you write about?
  • #13 16536726
    janek ie
    Help: 8
    Rate: 17
    in the glove box in the orphanage under the dashboard it is English passat
    and where exactly is this resistance what you pictured
    domex32
    Help: 585
    Rate: 2450
    There you have the resistance from the cabin fan and the radiator fan doesn't work.
    domex32 wrote:
    On the left side member you have
  • #15 16536841
    janek ie
    Help: 8
    Rate: 17
    ok, I found it, what should be the voltage on the outputs
    Added after 13 [minutes]:
    no 12 volts is 4.6 volts does it mean that the resistor is damaged
  • #16 17189178
    KierowcaMarcin
    Rate: 13
    Can anyone write what brushes I should use in the air conditioning fan?
    Copper graphite?
    Coal?
    On the internet, from what people often wrote, they are supposed to be graphite copper, but the master I gave them for replacement says that these are for starters, not devices, where they will work for a long time. I don't see any copper admixtures in the original brushes, which could confirm his words.
  • #17 17406647
    janek ie
    Help: 8
    Rate: 17
    hello, like a colleague Domex32 wrote, I replaced the resistance bar underneath the longitudinal member thanks for help
✨ The discussion revolves around troubleshooting the air conditioning fan in a VW Passat B5. The user has replaced brushes, checked fuses and relays, and confirmed the pressure sensor is functional. They seek advice on bypassing resistors to test the fan's operation in the first gear, as it only activates in the second gear. Responses include suggestions for checking voltage at the fan's connector, identifying the location of resistors, and confirming the type of brushes needed for replacement. The user eventually finds the resistor and seeks clarification on the expected voltage outputs.
