Peugeot 307 2005 RHR 2.0 - Error P1598 - Coolant bypass solenoid circuit
Frost160 29559 3
  • #1 17170973
    Frost160
    Help: 9
    Rate: 183
    It happens that it heats the coolant to over 100 ° C, the only error is P1598.
    The problem is that the thermostat comes with a valve (generally 3 plugs come to it), you can't buy a new one anywhere.
    I called the ASO, but "they don't have a drawing and can't say anything" you know.
    Has anyone done this before and know if there is a replacement? Did the French invent something again in this car?? I did in the newer 2.0 RHR because 2007 and there is no metal valve there and you can buy one for PLN 200.
    It's about the valve to which the blue plug comes from above.
    Thanks for any help.
  • #2 17172290
    decybel91
    Help: 1023
    Rate: 4224
    I don't have anything in my catalog either, just a newer type. In the ASO after the VIN number, they did not find anything? Weird. I suspect that you can install a newer type of thermostat and code the one present in the ECU. Look for someone with a service PSA computer.
  • #3 17172343
    Frost160
    Help: 9
    Rate: 183
    Only the guy at the dealership told me that they have some (no drawing) and you need to buy "some" tube plus a screw for it, so I suspect it will be as you say.
  • #4 20446538
    krzysztoftarka888
    Go to the Peugeot or Citroën service with the VIN number, there is a replacement. Another engine cover, to which the thermostat solenoid valve, another thermostat and an additional pipe for coolant circulation are mounted. Expensive business, about a thousand, but it works and you will forget about the problem of engine overheating.
