Hikvision Remote Viewer Ceases Functioning Every 5 Days: Hik-Connect Issues
tablica24 11901 8
  • Hik-Connect device re-add needed every 5 days
    #1 16540098
    tablica24
    Rate: 61
    Hello. I have a problem with the online preview in the recorder. Well, the problem is that the program to watch cameras on the phone stops working regularly every 5 days. The preview is made using the hik-connect function, i.e. without opening the ports, fixed ITP IP address. for everything to work again I have to log in to the site
    https://www.hik-connect.com/devices/page
    Remove the recorder, add it again using S / N and the verification code and it starts working properly ... which is terribly annoying already. What could be the reason that it doesn't work ?? Of course I have the Internet at home and it works very well.
  • #2 16541608
    Zielonka
    Help: 55
    Rate: 45
    Enter the model of the recorder and what program on your phone you are using.
    WB
  • #3 16542179
    tablica24
    Rate: 61
    Rejerstrator HIKVISION DS-7616NI-E2/A
    Program na telefonie - IVMS-4500
  • #5 16543732
    Mar_rcin
    Help: 7
    Rate: 8
    Stan-Mar wrote:
    IVMS-4500 will no longer be updated by Hika. Every few days a login occurs. Recommended by HIK-Connect.
    But hid-connect in the web version is still very modest.
    There is no Friend Management, for example.
    Alarmy Krakow
    os. Krakowiaków 45A, Kraków, 31-964 | Tel.: 607XXXXXX (Show) | Company Website: https://alarmy.krakow.pl
  • #6 16562784
    tablica24
    Rate: 61
    Okey, I understand everything.
    I need a few more answers to my questions.
    1. What is Friend Management. ?
    2. Is there any program from HIKVISION on the PC that after entering the login and password I have a preview of the computer from anywhere?
    3. Am I able to connect to my recorder a camera other than a hik, e.g. 8 level IP?
    4. What is the name of the device that converts LAN into HDMI and is previewed on TV, how do you program it?
  • #7 16562909
    michualex
    Help: 82
    Rate: 134
    Sharing the recorder to other users.
    iVMS-4200
    Yes
    Converter, extender. It is not programmed. Plug and Play device
    MK ALARMY
    Widziszewo, Długa 3, Kościan, 64-000 | Tel.: 663XXXXXX (Show) | Company Website: www.mkalarmy.pl
  • #8 16562969
    tablica24
    Rate: 61
    Thank you for your answer :) . Back to the topic. The problem with the recorder was the interruptions in the internet supply. The HIK app works very well.
    Now from a different tap, does anyone have an idea for a mobile camera?
    Camera with memory card and remote access to it.
    In short, a camera suspended on a tractor to which I have access to live view.
    When adding an IP camera called NEO Coolcam NIP-06BGPW3A0 300KP Network IP Camera w / Wi-Fi / IR Night Vision - Gray. As what to add it as what camera since there is no such model on the recorder.
    No onvif function. Therefore, the camera could not be added. greetings
  • #9 16944820
    tablica24
    Rate: 61
    A permanent address solves problems. Works after IP and Cloud.
The discussion revolves around issues with the Hikvision DS-7616NI-E2/A recorder, specifically the Hik-Connect function, which ceases to function every five days. The user experiences interruptions in online camera previews via the IVMS-4500 app, requiring them to re-add the recorder on the Hik-Connect website to restore functionality. Responses indicate that IVMS-4500 is no longer updated, and users are encouraged to switch to Hik-Connect. The conversation also touches on additional queries regarding features like Friend Management, PC software for remote viewing, compatibility with non-Hikvision cameras, and devices for converting LAN to HDMI for TV viewing. The user later identifies internet supply interruptions as a potential cause for the issues and seeks advice on mobile camera options.
