Hikvision DS-7616NI-E2/A: Hik-Connect vs iVMS-4500 & iVMS-4200 Preview Online Cameras Setup
lisster 21771 10
How can I view Hikvision cameras remotely on a PC without freezing, and can I use iVMS-4500 instead of Hik-Connect?
Yes—you can use iVMS-4500 for viewing, but several replies recommend abandoning the Hik-Connect cloud and using DDNS/port forwarding instead, for example with noip.com, because Hik-Connect can be unreliable [#17055002][#17120118] For the PC preview in iVMS-4200, switch the cameras to the auxiliary stream; the phone app already uses the auxiliary stream, while the PC may be pulling the main stream, which is heavier [#17115152] One user reported that lowering the stream quality reduced the freezes somewhat, although it did not eliminate them completely [#17055679] Another suggestion was to verify the upload link with a speed test, but the line was reported as within spec, so the cloud path remained the suspected bottleneck [#17056222] One reply also noted that iVMS-4500 is the older app and Hik-Connect is the newer one, so they are not exactly the same product [#17117657][#17119742]
  • #1 17054917
    lisster
    Rate: 13
    I have a Hikvision DS-7616NI-E2 / A recorder in the company plus 7 Hikvision DS-2CD2120F-I cameras.
    I put neostradę 80Mb / s on 8Mb / s and through the account hik-connect.com I have online cameras.
    In the phone I first installed the Hik-Connect application, I was able to configure everything. Cameras load, although the application itself is a bit strange in the sense of comfort of work. So I installed the iVMS-4500 app where cameras are much better viewed.
    What is the difference in these applications, can I use iVMS-4500 and remove Hik-Connect?
    As for me, they serve the same and do not really understand the meaning of creating two.
    In both the image works smoothly, however, it is better to use the browsing on the iVMS-4500.
    I also wanted to have a preview of the cameras from the company at home on the PC.
    I installed iVMS-4200. I added a HiDDNS device in device management.
    I entered my data from hik-connect, all cameras have been imported.
    It works, but it cuts strongly and muli. After clicking on the preview of 4 cameras, I wait about 6 seconds. to load the image.
    The picture is cut, frozen and after a while it starts again. Even if I start one camera, the picture is not smooth.
    The program shows the use of the network at 0% CPU level 7-9%. Having a phone connected at home to the WiFi itself as a PC on a smartphone, the picture is smooth and cuts heavily on the computer. What are the reasons for this and how to solve the problem?
    Greetings.
    jojohny
    Personally, I would use the iVMS-4500 application (I also use it).
    I would give up hik-connect.com and go to, for example, noip.com.
    I had very similar symptoms on the account of "hik-a". I think that they are caused by, for example, overloading their servers. After configuring the noip, it works perfectly.
  • #3 17055679
    lisster
    Rate: 13
    Thanks, I changed the house on the PC in the iVMS-4200 stream to the auxiliary. Image quality has dropped and cuts a little less, although it still sometimes freezes for several nice seconds.
    I wonder if this is the bandwidth of the bandwidth in the company - sending data or maybe servers on the hikconnect.com site?
  • #4 17056222
    jojohny
    You wrote that you have shipping up to 8mb. Maybe it is worth doing a simple test, for example on speedtest.net to confirm whether the link holds parameters. But what would not have been, you have a link by parameters too much to transmit the image.
    I repeat the suggestion regarding the transition to noip.
  • #5 17114130
    lisster
    Rate: 13
    I checked, the link is holding the parameters. I still use the preview by hik-connect.com. Sometimes it's really OK, and sometimes it cuts or freezes the image. I do not really know why there are such discrepancies in the fluidity of the preview, but from observations I suppose it is probably the fault of the hik-connect servers that sometimes have problems. Can anyone confirm my guess?
    I will probably have to do tests for noip.
  • #6 17115152
    Gutek1512
    Help: 39
    Rate: 37
    the phone takes the auxiliary stream, the PC can take the main one, switch to the auxiliary and see if it also cuts. The VMS itself is resource-consuming so the machine should also be of sufficient freshness.
  • #7 17115195
    lisster
    Rate: 13
    iVMS has an auxiliary stream. Intel I7 and 16GB ram should be enough, so the problem is not really on this side ;)
    I'm interested if there are other users who connect through hik-connect and have similar problems as me.
    I would like to make sure that this is the fault of hik-connect servers.
  • #8 17117657
    Fotodetektor
    Level 30  
    Help: 101
    Rate: 335
    The point is that the iVMS-4500 will be blacked out and not supported. The new one is and it is leading.
    OMNI-SAT
    WP 11, Wołów, 56-100 | Company Website: www.omnisat.pl
  • #9 17119126
    lisster
    Rate: 13
    New in the sense of a phone app called Hik-Connect?
  • #10 17119742
    Fotodetektor
    Level 30  
    Help: 101
    Rate: 335
    Exactly mate. This one is now up-to-date and the old one is also a different matter ;)
    OMNI-SAT
  • #11 17120118
    makosuu
    Help: 369
    Rate: 370
    You'd better make DDNS and redirect ports, not a cloud that likes to run on average.
The discussion revolves around the use of Hikvision's DS-7616NI-E2/A recorder and DS-2CD2120F-I cameras, focusing on the comparison between the Hik-Connect and iVMS-4500 applications for remote camera viewing. Users report mixed experiences with Hik-Connect, citing issues with image freezing and server reliability, while finding iVMS-4500 to provide a smoother viewing experience. Suggestions include switching to a different DDNS service like noip.com for potentially better performance. The iVMS-4200 software is also mentioned for PC access, with users exploring bandwidth limitations and server performance as possible causes for viewing issues. Concerns are raised about the future support of iVMS-4500, with indications that Hik-Connect is the newer, supported application.
