Hik-connect Offline Device & No DHCP: Troubleshooting Hikvision 7616 K2, IP Cameras & Routers
DariuszCCTV 19488 5
  • #1 17405122
    DariuszCCTV
    Rate: 8
    Hi.
    I have connected hikvision cameras to the Hikvision 7616 K2 recorder.
    The recorder has an IP of 192.168.1.4. The cameras have the address 192.168.1.10-22
    The preview on the monitor works.
    Internet is from Orange (landline). The router connected to the socket has IP 192.168.1. (On the ground floor) and it is transmitted via WiFi to the second router (repeater) with the address 192.168.1.80 (upstairs). The Internet works correctly on both routers. I have a router on the first floor connected by a LAN cable to the recorder.
    The problem starts when I want to start camera preview on my phone via Hik-connect.
    By. Internet instructions in the recorder options - on the network - I need to enable DHCP.
    Then I lose the video from the cameras on the monitor (they work only when the recorder has static IP enabled).
    In the next tab - access to the platform - I turn on Hik-Connect. I gave the access code and the device status changes to Not connected 0x1007.
    I've already tried:
    - Leave the static recorder IP on the network and enter DNS 8.8.8.8 and 8.8.4.4
    - enable recorder DHCP and try to connect to it without video from cameras
    - I set up port forwarding on both routers to try to connect to the recorder rigidly via IP / Domain
    Nothing works.
    My guess is that until my recorder is online, I will not be able to connect to it. But how to do it?
    Thank you in advance for any help! :)
  • #2 17405391
    xury
    Automation specialist
    Help: 878
    Rate: 1498
    Have you registered and added the recorder at euauth.hik-connect.com?
  • #3 17406483
    yvv
    Help: 43
    Rate: 62
    Is it possible, if on the floor you connect your laptop with a LAN cable to the router. Do you have internet on it? Remember to turn off WiFi on your laptop.
  • #4 17407008
    Fotodetektor
    Level 30  
    Help: 101
    Rate: 335
    You do not need to enable DHCP. Provide addressing outside the router's address pool for the recorder.
    You don't have a net in NVR.
    OMNI-SAT
    WP 11, Wołów, 56-100 | Company Website: www.omnisat.pl
  • #5 17408876
    marek216
    Help: 1077
    Rate: 932
    For clarity:
    This monitor is connected directly to the recorder or in the local network? Because the description indicates that it is a monitor from the computer and not a direct view.
  • #6 17416340
    DariuszCCTV
    Rate: 8
    It turned out that the fault was in the recorder. Only after logging in to him via computer, his status changed from offline to online. I have no idea why it happened, I met it for the first time. I did nothing but log in to the recorder through the browser.
    Thank you all for your willingness to help! :)
