Reading IMMO Pin from Jaeger Meter Input in Audi A3 1.6 with Motorola HC12 & UPA Programmer
salyvan2309 8367 10
How can I find the IMMO PIN for an Audi A3 Jaeger cluster read with Motorola HC12 and UPA, and is the dump usable?
Try login/PIN 1534 with mileage 149,904 km; that was the value the thread later confirmed as correct. An earlier guess of 09076 with 149,248 km did not work, and the cluster software was suspected to be damaged [#16542722][#16698578][#16748605] If the immo light keeps flashing, one user reported that changing the number of keys in adaptations from 2 to 1 made the cluster accept the calculated login and allowed adding the second key normally [#16932553]
  • #1 16541617
    salyvan2309
    Rate: 9
    Hello. Will any of your colleagues help in reading the "IMMO" pin from the given charge?
    The batch was read from the meter, with the Motorola HC12 with the UPA programmer. Alternatively, I am asking for an estimate whether this input is suitable for anything because I have doubts myself.
    • A3_odczyt_HC12.bin (2 KB) You must be logged in to download this attachment.
    spmotors
    Rate: 9
    pin 09076 and mileage 149248km check if it works.
  • #3 16543527
    salyvan2309
    Rate: 9
    Thanks mate spmotors for your interest in the topic. Today I was at the second specialist with this counter and the counter does not accept any pin (including the one you gave).
    At the moment, the meter software has been found to be damaged, although a miracle may happen and someone will find an easier way to do it.
    the counter is of course 8l0920900F 1/2 FIS Jaeger with white backlight
  • Second key added by resetting channel 00 and setting channel 21
    #4 16547234
    salyvan2309
    Rate: 9
    Such a detail from today - I managed to add a second key to the clocks, although they still do not accept the pin, I do not know how it happens.
    After unscrewing the clocks and disconnecting them for about a minute, I reconnected and entered with the Vag in "instruments (17). In adaptations (10) on channel 00 I reset the values, then on channel 21 I entered the number of keys" 2 "and confirmed.
    I put in the second (non-original) key when the immo light stopped flashing for a moment, now both the car is burning, although the light is still flashing.
  • #5 16696789
    Slezny
    Hello, I also have a problem with reading the PIN from the jaeger meter, like a colleague above the engine, also 1.6 benz. I am asking for help and thank you in advance :)
    • eeprom_a3.rar (491 Bytes) You must be logged in to download this attachment.
  • #6 16698578
    spmotors
    Rate: 9
    What's your mileage now?
    Added after 8 [minutes]:
    Login 1534 and mileage149904km check if it works
  • #7 16748605
    Slezny
    The most correct PIN, thank you, MAN!
  • #8 16787608
    Angest
    Rate: 10
    I warmly welcome.
    I will connect to the topic.
    I want to add the keys to the immo in the Audi A3 88rok, meter 8L0919860D.
    Unfortunately, the cable does not go and FAIL pops up on the meter.
    I read the 93C56 eeprom and PIN 0719 comes out of my calculations
    Please confirm.
    File attached
    • A3_93C56.BIN (256 Bytes) You must be logged in to download this attachment.
  • #9 16826093
    albert
    More like 98 and pin 1907.
  • #10 16826715
    Angest
    Rate: 10
    I've already figured it out, but thank you very much
  • #11 16932553
    salyvan2309
    Rate: 9
    Hello. By a strange coincidence, I managed to extinguish the flashing immo light. I changed the number of keys in adaptations from 2 to 1, now even the counter takes the login calculated earlier and by a friend from the forum. I have added the 2nd key normally and everything is fine. Thank you for your interest.
The discussion revolves around reading the IMMO pin from a Jaeger meter in an Audi A3 1.6 using a Motorola HC12 and UPA programmer. Initial attempts to retrieve the pin yielded a value of 09076, but subsequent tests revealed that the meter software was damaged, preventing the acceptance of any pin. Users shared experiences of adding keys to the IMMO system despite issues with the pin, including resetting values in the VAG software and successfully programming a second key. Various pin codes were mentioned, including 1534 and 0719, with some users confirming successful key additions after troubleshooting. The conversation highlights the challenges faced with the Jaeger meter and the importance of software integrity in the process.
