Flooded Xbox One S: Cat Urine Damage, Auto Shut-off, Power Supply Issue & Possible Faults
kamboy3 11583 15
Why does an Xbox One S start and then shut off after being urinated on by a cat, and what should be checked or cleaned?
Cat urine can cause immediate corrosion and shorts, so simple drying is often not enough. Thoroughly clean the entire board with isopropanol; if there is no physical damage, the console may still come back to life after complete cleaning and drying [#16569887][#16545366] Check the RAM power section around 9/B/C and inspect SMD capacitors, because that area can be involved in the fault [#16548883] If the urine got under BGA packages, the problem may be much more serious and even heating may not help [#16569887][#16570102]
  • #1 16544786
    kamboy3
    Hello, tonight the cat pissed on my xbox one s ...
    I dried it with a dryer and then started it. It starts but turns off automatically.
    I took it apart, under the power supply I noticed a strange dried "something".
    My question is what could have happened and where is the fault?
  • #2 16544801
    badboy84
    Help: 1197
    Rate: 1486
    This dried "something" is what the cat cried, that is, pissed :lol: maybe the disc should be washed in isopropyl alcohol? because it causes a short circuit, therefore the console turns off if it has not been damaged by short circuits. Drying is not the end of "repair".
  • #3 16544805
    kamboy3
    Where can I buy this alcohol?
  • #4 16544824
    nici
    Help: 266
    Rate: 979
    In an electronics store.
    I hate cats for such miracles. The coat would be lying outside.
  • #5 16544825
    badboy84
    Help: 1197
    Rate: 1486
    I once bought an allegro, I use it generally for degreasing all surfaces. I do not know to the end whether it is possible to treat the motherboard with it and you certainly do not need to clean all the dirty places. It should also be in electronics stores. I would also use a delicate brush so as not to break something on the disc, the cloth will not get anywhere.
    PS cat alive? :)
  • #6 16544842
    kamboy3
    He lives like that, but don't let him show me in the eyes.
    I tried to clean the cleaner lightly, but it doesn't give the effect: /
  • #7 16545366
    beo
    Level 37  
    Help: 298
    Rate: 238
    But is it the cat's fault that he was not taught to take care of the needs of the litter box? :D However, I would be inclined to thesis, malice - I do not think that the console confused him with the litter box. First, thorough cleaning of the entire plate - if there is no damage, there is a chance that after drying, it will come back to life.
  • #8 16545567
    kamboy3
    The cat is 14 years old, she is taught from a small one to settle down in the litter box, but simply bounces her in old age. Peeing on the washing machine, sink etc ...
    I cleaned the disc and lies down, I tried to fire again and the same.
    Does time matter, say in 2 days it can come alive?
  • #9 16546158
    nici
    Help: 266
    Rate: 979
    Spade, hole and after work.
    You can even drown the whole disc in IPA, it will be fine.
  • #10 16546176
    kamboy3
    I will try to wash it in it, but I do not know where to buy this alcohol ...
  • #11 16546310
    nici
    Help: 266
    Rate: 979
    I have already written in an electronics store.
    if not allegro.
  • #12 16546347
    badboy84
    Help: 1197
    Rate: 1486
    nici wrote:
    You can even drown the whole disc in the IPO, it will be fine.
    IPA ...
  • #13 16546367
    nici
    Help: 266
    Rate: 979
    badboy84 wrote:
    IPA ...
    Seriously The typo is in.
  • #14 16548883
    Krzychu K.
    Help: 50
    Rate: 100
    section 9 / B / C is responsible for supplying RAM
    wash the disc with isopropanol as this will not help to check SMD capacitors / replacement within
    something called a human friend of this place.
  • Cat urine corrosion may damage BGA chips
    #15 16569887
    obsid
    Help: 71
    Rate: 52
    Flooding electronics and drying, as a rule, gives a good effect when it is possible to completely eliminate even moisture particles. In the case of "marking by a cat" [the cat likes warm objects and is to mark them as its new property in nature] the problem is not so much moisture as the extremely aggressive nature of the "liquid" causing almost instant corrosion. To sum up - unfortunately the problem may turn out to be much more serious if "moisture" got under BGA systems ...
  • #16 16570102
    nici
    Help: 266
    Rate: 979
    obsid wrote:
    Unfortunately, the problem may turn out to be much more serious if "moisture" got under BGA systems ...
    You are right, even a thorough heating can do nothing here.
    obsid wrote:
    the cat likes warm objects and is supposed to mark them in nature as its new property
    ... I would recommend inside the oven.
The discussion revolves around an Xbox One S that was damaged by cat urine, leading to automatic shutdowns after initial startup. Users suggest that the dried substance found under the power supply is likely urine, which can cause short circuits and corrosion. Recommendations include cleaning the affected areas with isopropyl alcohol (IPA) and using a delicate brush for thorough cleaning. Concerns are raised about potential long-term damage, especially if moisture has penetrated critical components like BGA systems. The importance of completely eliminating moisture and the aggressive nature of cat urine are emphasized, with some users humorously commenting on the cat's behavior.
