[Solved] Xbox ONE Fat Console Shuts Down After 5 Seconds: Seeking Solutions
Dejv11234 27537 7
  • #1 18086741
    Dejv11234
    Level 4  
    Good day, I have a problem with the console as described
    The console starts up for 5 seconds then shuts down. No failure modes etc do not work. Can anyone give me a hint as to what could be screwed up? I know it's looking for a needle in a haystack, I can give pictures of the whole motherboard.
    A review video of what it looks like:
    [video:abd256847d]https://filmy.elektroda.pl/97_1564419722.mp4[/film:abd256847d].
  • #2 18086867
    Grzegorz740
    Level 37  
    Help: 313
    Rate: 553
    Check if the fan is working. To me it looks like overheating of the processor and as if the protection tripped.
    How did it happen that the console started to shut down after 5 seconds?
  • #3 18086875
    Dejv11234
    Level 4  
    The console was simply turned off and moved from point a to point b. The processor does not overheat, I touched it with my finger and it slightly heats up.
    As there is a possibility that it is something with the power section on the motherboard, or the power supply?
    I will add that there is no image.
  • #4 18087648
    xbox-serwis.eu
    Help: 52
    Rate: 210
    Hi, so from experience I'll write...
    With problems with the power section, it would not respond to the power button or would shut down after 1-2 seconds.
    I bet cold solders under the sock, that is what most consoles sooner or later get - REBALLING :) Fact that it happened after moving the hardware.... Pure coincidence...
    XBOX-SERWIS.EU
    Karmelicka 15, Kraków, 31-131 | Company Website: http://www.xbox-serwis.eu
  • #6 18088194
    Dejv11234
    Level 4  
    xbox-serwis.eu wrote:
    Hi, so from experience I will write...
    I'm betting on cold solders under the proc, which is what most consoles get sooner or later - REBALLING :)
    Well, and the processor heats up when there are cold solders?
    Is it viable to reballing? Or worse, replacing the processor?
  • #7 18088199
    xbox-serwis.eu
    Help: 52
    Rate: 210
    Yes, it can be powered after all. Today I made such a board, with identical symptoms.
    I immediately picked up the bridge, because some genius flooded the xcgpu and sb with a bad flux and overheated. Doing an update just :) .
    XBOX-SERWIS.EU
  • #8 18106847
    Dejv11234
    Level 4  
    I close the topic, damaged motherboard (probably the processor).
The Xbox ONE Fat console experiences a shutdown after 5 seconds of operation, with no error codes displayed. Initial suggestions include checking the fan for overheating issues, but the user indicates the processor does not overheat significantly. The discussion shifts towards potential power supply or motherboard issues, with a focus on cold solder joints as a common problem in consoles. Users recommend reballing as a possible solution, citing experiences with similar symptoms. A user also shares links to YouTube videos that may provide further insights into fixing broken Xbox consoles. Ultimately, the user concludes that the motherboard is likely damaged, possibly affecting the processor.
