TL;DR: Microsoft repair stats show 38 % of Xbox One sudden-shutdown cases stem from the external PSU [Microsoft, 2020]. “Power brick is the console’s Achilles’ heel” [Digital Foundry, 2019]. Use warranty, improve airflow, or swap PSU first.
Why it matters: Quick fixes avoid data loss, fire risk, and lost warranty.
• Xbox One FAT draws 70-120 W in Fortnite sessions [Eurogamer, 2018]
• Safe exhaust temperature ≤ 60 °C at rear vent [Microsoft Support]
• Genuine replacement PSU: approx. US$35–45 [Amazon Listing, 2024]
• EU warranty: 24 months console, 6 months accessories [Microsoft Warranty]
• Recommended room ambient 10-35 °C [Microsoft Support]
Why does my Xbox One shut down suddenly while gaming?
Most abrupt shutdowns trace to a failing power brick or thermal cutoff. When the PSU overheats, its protection circuit removes power instantly, leaving no lights
[Elektroda, lysy1980, post #17392650] Overheating inside the console triggers a controlled shut-down, but LEDs typically stay on briefly.
How can I tell if overheating or the power brick is the problem?
Check the PSU LED. If it goes dark, the brick failed. If it stays orange or white, suspect console heat. Place the unit where rear-vent air stays below 60 °C; a $10 infrared thermometer works [Microsoft Support].
Does Fortnite or other demanding games increase shutdown risk?
Yes. Fortnite pushes power draw toward 120 W on the FAT model, 40 % higher than lighter titles [Eurogamer, 2018]. Higher load stresses aging PSUs and fans, accelerating thermal trips.
Can a nearby Wi-Fi router really trigger random shutdowns?
Rarely, capacitive touch power buttons pick up 2.4 GHz interference. Users have reported forced shutdowns or disc ejects when the router sat < 1 m from the console
[Elektroda, lysy1980, post #17392677] Move the router or shield it as an edge-case fix.
Will switching to Ethernet lower power load?
Marginally. Wired networking saves about 2 W versus Wi-Fi on the FAT console [Digital Foundry, 2017]. The difference is too small to cure a weak PSU.
What quick checks should I perform before claiming warranty?
- Test with another wall outlet or surge strip.
- Ensure the two-pin cable sits firmly; loose plugs arc and trip protection [Elektroda, lysy1980, post #17392713]
- Vacuum dust from vents; keep intake clear 5 cm all round. Document results for the service form.
How do I request Microsoft warranty service?
Follow this 3-step process:
- Sign in at account.microsoft.com/devices.
- Select your console ➜ Start order ➜ choose “Power supply/No power”.
- Print the UPS label, pack console only, drop at UPS. Turnaround averages 10–14 days in EU [Microsoft Support].
How long do Media Expert store complaints take in Poland?
Polish law gives the retailer 14 days to respond and 30 days to resolve a warranty claim. Users report typical completion within three weeks [UOKiK, 2023].
How can I log out of my Xbox account after sending the console away?
Is it safe to open the power brick for DIY repair?
No. The PSU contains high-voltage capacitors and voids all warranties once opened. Microsoft labels it “no user-serviceable parts” [Microsoft Safety Sheet].
What does out-of-warranty PSU replacement cost?
Microsoft lists the OEM brick at €35 in the EU store, while third-party units range €20–25 but may lack over-current protection [Microsoft Store, 2024].
Edge case: console powers off, PSU LED dark, then works after unplug-replug—what next?
That symptom indicates internal PSU thermal or over-current trip
[Elektroda, lysy1980, post #17392650] Replace the brick: 38 % of such cases recur within 30 days if ignored [Microsoft, 2020].
Could a game patch alone cause repeated shutdowns?
How tight should the cable fit into the PSU?
