TL;DR: Adjust through left-side 60 × 60 mm inspection window; set 8 mm (1st) and 12 mm (2nd) lever–bearing gaps. “First stage set to 8 mm, second to 12 mm” [Elektroda, FAB 2002, post #16895721]
Why it matters: correct clearances stop slip, protect PTO and extend clutch life.
• Old-type clutch: 3 release levers; new-type: 6 levers [Elektroda, sewo.k, post #16545900]
• Recommended gaps – old type: 4 mm (drive), 8 mm (PTO) [Elektroda, darekstrz, post #18182535]
• Recommended gaps – new type: 8 mm (1st), 12 mm (2nd) [Elektroda, FAB 2002, post #16895721]
• Disc diameter grew from 224 mm to 225 mm after tractor No. 391570 in 1987 [Elektroda, BANANvanDYK, post #17534963]
• Two glow plugs sit in the intake manifold [Elektroda, piotrekwoj1, post #16545030]
Where exactly is the clutch adjustment window on an Ursus C-330?
How do I tell whether my clutch is old or new type?
What clearance values should I set on the old-type (3-lever) clutch?
What clearance values suit the new-type (6-lever) clutch?
How do I perform the adjustment through the inspection window?
- Rotate the flywheel until a lever appears in the window.
- Loosen its locknut, then turn the inner nut until the feeler gauge (8 mm or 12 mm) fits snugly.
- Hold the inner nut and tighten the locknut. Repeat for every second lever until all six/three match [Elektroda, FAB 2002, post #16895721]
Where are the glow plugs located?
Are C-330 and C-330M clutch discs interchangeable?
Why does my tractor stop moving with only slight pedal pressure?
What tools and gauges are required?
The clutch jerks after installing a new disc—possible causes?
Can I improve the tactile separation between stages?
What size wrench locks the release-lever nuts?
