Audi A3 8P 05 \ '- Test of clocks after turning the ignition
leonbak 18156 2
  • #1 16546323
    leonbak
    Rate: 27
    I was interested in the topic of the clock test, is it possible in the 8p of 2005? I found a short info ( HERE ) how to set it in VCDS but whether it will work in 8P version or it only applies to 8V and so on.
    Film from 08+
  • #2 16547117
    marci4
    Help: 169
    Rate: 177
    Needle Sweep (because this is the name of this function) can only be activated in the S3 clocks in the case of the Audi A3 8P.
  • #3 16573720
    leonbak
    Rate: 27
    Thanks great for the info :)
