Change of the second grade of technical secondary school to the second grade of
nerff 30621 3
  • #1 16546835
    nerff
    Hello. Today I was promoted to the second grade of secondary school, but I am not interested in the current profile and I would like to change it to the second grade of secondary school. Today I was in the office and the lady told me that it was impossible because the law says so and I can only transfer to the first year of high school. I don't want to be a year in the back. As I asked my high school friends, there is practically no difference in the curriculum, or it is small and I could make up for it. Is there anything you can do to transfer to this second grade? A placement test or something? I don't want to waste a year. I could even complete a whole year if needed. I am ready for anything: /
  • #2 16546901
    bodzio507
    Level 30  
    Help: 22
    Rate: 579
    Did you talk to the secretary or someone from the management? Were you alone or with your parent?
    If you are not of legal age, you should be with your parent and hit the director right away.
    In my opinion, there should be no formal problems with this. Possibly some program differences need to be made up for. Because high school, however, goes faster with the material and may have other extensions.
    There may be a problem here that you choose too good a school that has too many students and does not want to accept more students from the technical school.
    I am surprised that it took you a year to come to the conclusion that the technical school is not for you. You'd be better off moving in the middle of the year.
    Moderated By telecaster1951:
    3.1.11. Don't post messages that add nothing to the discussion. They are misleading, dangerous or do not solve the user's problem.
  • No transfer option from technical school to second grade
    #3 16547489
    telecaster1951
    Help: 829
    Rate: 818
    @ bodzio507 Buddy, if you are not sure then don't advise.
    Nothing can be done. Your situation is mentioned in § 2 para. 1.point 5 of the ordinance of the Ministry of National Education of August 13, 2015.
    The student moving from:
    5) class I or II of a public or non-public technical high school with the rights of a public school may be admitted to the first class of a public general secondary school;
    Whereas point 7 says:
    Class III of a public or non-public technical high school with the rights of a public school may be admitted to class II of a public general secondary school or to class III of a public basic vocational school in an occupation in which a common qualification was separated with the occupation in which education was carried out in a technical high school, provided that took the examination confirming this qualification;
    There is no other option.
  • #4 16547554
    E8600
    Help: 529
    Rate: 2520
    Apparently, it changed here, because I had a few buddies who moved from technical to high school and it was not a problem, but it was a few years ago. It is true that the high school was extramural - studies on Friday evening, Saturday and Sunday. May I ask you what profile of technical school have you chosen?
