Italico Espresso Machine: No Coffee Output - Possible Valve Blockage?
Sgit 9741 1
  • Suspected blockage in capsule valve assembly
    #1 16556803
    Sgit
    I have a problem with Italico. The first defect he had was a water leak from the housing, after reading the post and advice of forum members, I undressed it and found a broken valve. I exchanged for delonghi as forum members advised, it works, draws water, heats, but coffee does not fly or even boiling water.
    I disassembled the boiler, a lot of stone, which the capsule does not clean, but I could not disassemble the valve with the green seal that contacts the capsule (valve and seal and three teeth to pierce the capsule inside.
    The question is:
    what is the reason that the machine does not make coffee?
    can the valve with the green seal be clogged and how to disassemble it?
    I am asking for opinions and solutions
    thank you
  • #2 16662445
    kfaterka
    you need to use a socket wrench -17- and you can unscrew this element with a gasket and teeth, and inside the heater there is a valve - a rubber ball with a spring - which can be removed and the socket cleaned a bit !!!
    Good luck
    ps.
    I can not start the pump that does not feed water to the heater, buzzing and does not give even though I start it without any hoses.
