VW Passat B5 FL: STOP BREAK FAULT SERVICE MANUAL Message Persistence Despite Brake Fluid Refill
elman2 19647 1
  • #1 17195674
    elman2
    Rate: 32
    For some time now the message like in the subject has been appearing more and more often. It is probably associated with a low level of brake fluid. I added fluid, the problem persists. I'm thinking about a broken level sensor. Can anyone explain how he works? There is no float sensor on the cap, the sensor probably on the bottom of the tank. Is there a float in the tank, e.g. with a magnet?
  • #2 17197278
    MrokDuszy
    Help: 13
    Rate: 8
    And a colleague took out SITKO and checked exactly how much fluid there is ??? and whether a colleague has a vag to indicate if there is any error.
    Buddy, I would start with the rear brakes, check the pads because maybe they wiped off a lot and the piston would slide out the same in front, then I would check all the hoses for leaking brake fluid somewhere, and at the end how everything would be correct, I would vent every wheel for sure, I don't remember if your tank on top has, like in golf, a button to test the signal, maybe some dirt has broken in.
