Re: Samsung A3 2016 Charger Detection but No Charging - Original Charger & Android Reset
aisak15 6684 10
Why does a Samsung A3 2016 detect the charger but not actually charge the battery?
If the phone detects the charger but still does not charge, the forum suggests a damaged charging line or charging socket rather than a bad charger. Trying another charger, cable, and even connecting to a computer did not change the behavior, which points back to the phone itself [#16182447][#16182463][#16182489] One reply specifically asked whether the phone had been dropped or flooded, because that can damage the charging path [#16182543] Another reply advised checking whether the first and last pins are green/corroded and whether moisture has entered the charging socket [#16186958] A software update was also asked about, but the OP said none had been done [#16183826][#16183895]
  • #1 16182375
    aisak15
    Hello. I have a problem with the Samsung A3 2016 phone, it detects the charger, but unfortunately it does not charge. The phone is connected to charging and the battery is still in place. After resetting the android, it's still the same. Original charger. Please help.
    Added after 5 [minutes]:
    I will add that the Smart Switch application detects the phone.
  • #2 16182447
    tino2003
    Admin of GSM Group
    Help: 1973
    Rate: 2089
    On another charger was checked?
  • #3 16182463
    actin
    Help: 187
    Rate: 799
    Have you tried under the laptop? Cable or plug change was?
  • #4 16182489
    aisak15
    It was checked and nothing.
    Added after 58 [seconds]:
    A connection to the computer has been attempted, it detects but does not charge.
  • #5 16182543
    actin
    Help: 187
    Rate: 799
    Possible damage to the charging line.
    Did he fall Flooded?
    The warranty is?
  • #6 16182574
    aisak15
    This has happened twice, the first time the phone did not even respond to charging, it was connected to some program through which it worked, the second time the phone was reset and worked, so the phone did not fall, it was not flooded and the warranty is not.
  • #7 16183826
    actin
    Help: 187
    Rate: 799
    Was the software updated?
  • #8 16183895
    aisak15
    No, there was no update.
  • #9 16184216
    actin
    Help: 187
    Rate: 799
    Have you tried charging off?
  • #10 16186139
    Spartan33
    Help: 41
    Rate: 97
    Suddenly it happened?
  • #11 16186958
    Szymek1989
    See if the first and last pins are not green and if they are in place, it looks like damage
    1.pin from charging
    2.charged charging socket
    3. moisture has arrived
The user is experiencing an issue with their Samsung A3 2016 phone, where the device detects the charger but does not charge the battery. Despite using the original charger and performing an Android reset, the problem persists. Suggestions from other users include checking with a different charger, inspecting the charging cable and plug, and ensuring the charging pins are not damaged or corroded. The user confirmed that the phone has not been dropped or exposed to water, and there is no warranty available. They also noted that the Smart Switch application can detect the phone, but it does not charge when connected to a computer.
