Installation / wiring in the house for video intercom / IP intercom
marcinx00 8952 12
How should I wire a house for a video/IP intercom so I have enough cables for the outdoor station, gate control, power supply, and two indoor monitors during construction?
Run both the twisted pair from the gate and the future power supply to the multimedia switchboard instead of splitting the installation into multiple places [#16564018] If the intercom also has to power the lock or gate opener, check the distance, but in any case all house-side cables should end in one central place for flexibility [#16564018][#16564703] For gate control, keep the extra twisted pair because it is used for control/opening, and joining the gate cables inside the building is only one possible, more universal option [#16564473][#16564703] For an IP video intercom, bring the twisted pair to the multimedia switchboard and then use UTP toward the monitors; one twisted pair per monitor is the minimum, but more is better [#16929581] For the indoor monitor points, a classic Fi 60 flush box is recommended, and if you want the doorbell sound heard through the monitor, run UTP there too because that depends on the model [#16929581]
  • Recommended cabling layout for IP video intercom and gate control
    #1 16563885
    marcinx00
    Rate: 34
    Hello, I have a question about the correct arrangement of cables for installing a video intercom.
    I have a strand buried in the ground (of course in a gel) it enters the building, my question is:
    1. Can lead the cable to the multimedia or electrical switchboard.
    If I bought a video intercom with a DIN rail power supply, then I have a place for it in the electrical switchboard.
    2. If I used this power supply for DIN in an electrical switchboard, do I have to get to this power supply with this twisted pair from the gate? Next, next to the multimedia switchboard and connect it to the router there, if it is to be an IP video intercom?
    Or maybe fly this twisted pair straight to the multimedia switchboard, and release only the power cable from the power supply?
    3. Is it possible to somehow coincide with the opening of the entrance gate - there is also a second twisted pair and a wire to supply 5 wires goes along the fence.
    I am asking for some picture diagram of what cables to release, so that it does not turn out later that I gave too few of them under the plaster.
    I would like it to be possible to connect two screens permanently on the walls (top and bottom), although it will be possible to fire on the smartphone and tablet via IP.
  • Recommend routing power and twisted pair to the multimedia cabinet
    #2 16564018
    suworow
    Help: 650
    Rate: 1278
    1,2 Why multiply entities and cut this wire. How does a colleague know that the power supply from the intercom will be for a DIN rail? Both the future power supply and the twisted pair are best if they reach a multimedia switchboard. The only question is about the distance and whether the future intercom will also power the catch.
    3. This wire runs from? down?
    Maybe some sketch please
    I corrected the title
  • #3 16564140
    marcinx00
    Rate: 34
    1 twisted pair goes from the gate, 2 from the gate + 1 cable 5 wires from the gate goes past the gate and all cables enter the building in one place.
    The building is still before plasters, so I ask you not to make mistakes when laying cables.
  • #4 16564291
    suworow
    Help: 650
    Rate: 1278
    This will connect a friend with a twisted gate and a gate. I asked about distance or do I just think? What cables did the colleague lay under the monitors? I would give there a twisted pair + power supply all led by roz. multimedia
  • #5 16564349
    marcinx00
    Rate: 34
    Twisted earth length about 20 m to the building.
    Length from the building wall to the switching station about 10 m, including a total of 30 m.
    I haven't given anything yet.
    Why give a twisted pair between a gate and a gate?
  • #6 16564473
    piotrek_falownik
    Help: 13
    Rate: 38
    This allows you to make the right connection and control the gate and gate :) ..
  • #7 16564610
    marcinx00
    Rate: 34
    So giving a twisted pair between the gate and a gate for this 2 twisted pair home and a 5-wire power supply cable at the gate is enough?
  • #8 16564626
    suworow
    Help: 650
    Rate: 1278
    I understand that this 5-wire cable is for powering the gate and not intercom?
    Yes, having a triangle installation can always be done.
    Regards
  • Suggesting an indoor splice for gate twisted pair
    #9 16564670
    marcinx00
    Rate: 34
    yes cable to power the gate.
    And out of curiosity whether this twisted pair between the gate and the gate could not be replaced by connecting these cables at home (since there are separate twisted wires from the gate and gate, the connection could be made inside the building) e.g. cable from pin 1 from the gate needs to be connected to the gate No. 2, i.e. at home, connect these two cables together and I have a connection between the gate and the gate
  • #10 16564703
    suworow
    Help: 650
    Rate: 1278
    A colleague himself will assess which solution gives more possibilities, is more universal. The cables in the house are connected in one place anyway.
    Regards
  • Questions on wiring and monitor cabling for IP intercoms
    #11 16925640
    marcinx00
    Rate: 34
    I have a few more questions from fellow experts on the subject of IP video intercoms
    1, how do I enter a twisted pair cable from a doorphone to a multimedia switchboard, can I use this switch to transfer the image to 2 monitors on a twisted pair cable and to get the image via WiFi on other devices such as a smartphone or tablet?
    2 from the switchboard I gave a 2x1.5 mm cable to power the monitor at the bottom and top depending on whether I need 230V or, for example, from a 12v power supply, so I only ask for a hint whether on the wall where the monitor will give a box or just put out the cables (I thought about cans of such square flush-mounted) how do you do it professionally?
    3 can you somehow rip the doorbell with such a video intercom so that the bell sound is heard through the monitor or are there video intercoms with this option?
    If it is possible, should you also give twisted-pair cable from the monitor door bell?
    4 is one twisted pair per monitor enough?
    Ircys
    Intercoms specialist
    Help: 1342
    Rate: 2085
    Without going into details - yes
    Give a can of classic Fi 60, for example
    It depends on the model, but if you are at the stage of laying the cable, then give UTP in this relationship.
    One twisted pair is the minimum, it's always better to give more.
    Regards
  • #13 16933238
    marcinx00
    Rate: 34
    thanks for the answers
The discussion revolves around the installation and wiring of video intercom systems, specifically addressing the arrangement of cables for connecting a video intercom to a multimedia or electrical switchboard. Key points include the use of twisted pair cables for data transmission and power supply considerations for both the intercom and the gate. Participants discuss the feasibility of routing cables from the gate to the switchboard, the potential for using a DIN rail power supply, and the importance of proper cable management during installation. Additional inquiries focus on the integration of multiple monitors, the use of WiFi for image transmission, and the possibility of connecting a doorbell to the intercom system. Recommendations emphasize the use of multiple twisted pairs for enhanced functionality and reliability.
