Golf V 1.6 8V Radiator Fan Not Turning On After Water Exposure: Short Circuit Solutions
dareczek3000 6570 1
  • #1 16564436
    dareczek3000
    Rate: 28
    Hello, I have a Golf v 1.6 8 v. My problem is the radiator fan not turning on. Such symptoms began with falling into considerable water. Wait for it to dry sometime, or look for a short circuit, but where?
  • #2 16564650
    coperfild
    Help: 291
    Rate: 1697
    See if you have such a module on the fan.
    Check with a light bulb if you have 12v on a red and brown thick wire, if not check the fuses under the hood.
