Lumia 535 Battery Not Charging Despite Power Supply - USB Socket Replacement?
Fidelis 6993 9
Why does a Lumia 535 detect the charger inconsistently or not charge the battery even though voltage is present at the USB socket, and is replacing the whole USB/microphone ribbon likely to fix it?
Replacing the complete USB/microphone power module is a common fix for this Lumia 535 charging fault, and in the reported case it solved the problem [#16572204][#16636356] Voltage present at the USB contacts or even at the factory test points does not by itself prove the connector is good; if the phone shows voltage but still does not charge, the fault can be on the motherboard side [#16565898][#16636356] One practical diagnostic suggestion was to measure the charging current, not just the voltage, because bad cables or too much resistance can stop charging around 30% [#16564810] The thread’s final result was that the complete power section replacement helped, while the USB connector alone was not the real cause [#16636356]
  • Charger detection failure points beyond USB socket
    #1 16564656
    Fidelis
    Rate: 140
    At first I suspected that the USB port was mechanically damaged. However, I measured the voltage at the USB output towards the phone and after connecting to the charger the power appears.
    Another matter: after connecting the charger, the phone does not "see" the charger at all. Other times the camera "sees" the charger, indicates charging, but in fact the battery in the phone does not charge (the charge level is still at the same value of 28%).
    What could be the reason for this behavior of the phone?
    Will replacing the entire USB socket with the microphone and "ribbon" (available to buy the network) help, or the fault lies elsewhere?
  • #2 16564810
  • #3 16564842
    Fidelis
    Rate: 140
    Fidelis wrote:
    Change the USB cable first.
    The USB cable is part of the Microsoft / Nokia charger. The charger easily charges other devices with a micro USB socket. I have several original chargers for micro USB and with each Lumia does not work.
    Do you mean the measurement of the charging current or the power supply of the entire phone?
  • #4 16564848
  • #5 16565898
    tino2003
    Admin of GSM Group
    Help: 1973
    Rate: 2090
    To begin with, replace the connector, just because voltage just after the connector does not mean that it is good.
  • #6 16572204
    KRY5PIN
    Level 37  
    Help: 312
    Rate: 467
    That will help, very common case in this Nokia. If you do not want to play in replacing the connector itself, and it is easier for you to replace the module, I would recommend.
  • #7 16585022
    Fidelis
    Rate: 140
    That's right Only earlier I would prefer to check the voltage reaching the board, and I do not know how. I just don't like to repair (exchange parts) "on the hook".
    I spoke to a service technician from whom I wanted to buy a ribbon with a USB socket, and that service technician, having learned the specific symptoms of charging problems, advised himself not to replace the power bar, claiming that the reason is probably on the side of the disc.
    Or i won't help. I would exchange if I was sure. It's not that I don't want to. Replacing (desoldering and soldering) USB socket at the price of the entire ribbon of 10 PLN, it is rather a job for enthusiasts of gouging and soldering. And maybe I would even do that .... but this price and above all the likelihood of making a mistake during assembly / disassembly - makes you lazy ;-)
    One more observation: I agreed to pick up the album in person. I turned on my phone to remove the disc and take it "in a pattern" so as not to be disappointed after the purchase. Something touched me to treat the whole disc and ribbon with contact cleaner. I submitted everything and it turned out that it helped! After folding, the phone recharged without any problems. However, when you try to top up again, you will not be able to top up again - the phone will not be charging again. Jacket, what and where can go there? Some "cold" micro-February or what?
    KRY5PIN
    Level 37  
    Help: 312
    Rate: 467
    What do you expect from us in this forum ??
  • #9 16585316
    tino2003
    Admin of GSM Group
    Help: 1973
    Rate: 2090
    I close the thread because without changing the whole subassembly, further discussion does not make any sense.
  • #10 16636356
    Fidelis
    Rate: 140
    Attached I publish a photo of the power supply system (with a microphone and USB, etc. ...) by Lumia 535, with marked points (including two factory test points), in which after connecting the power supply from the USB power supply must tension appears. The appearance of voltage in these places (without batteries) excludes a malfunction of the power supply system. A very common bug for this camera model, as it turns out (thanks to KRY5PIN!). If the voltage appears (smaller by value) and the charging is absent, then you can look at the "motherboard". The problem was not USB connector malfunction .
    In my case, none of the illustrated points (except USB contacts) of power at all there was no .
    Advice on direction diagnosis with his head on his neck, leaning back for measurements and your experience and not automatic system exchange "randomly" ;-)
    tino2003 wrote:
    I close the thread because without replacing the entire component further discussion does not make any sense.
    What does a common discussion (and on FORUM! Where there is no compulsion to answer) have a common sense with the sense of the alleged suggestion of the need to automatically replace the entire system, I really would like to know ... But sure ....! This is the easiest and most convenient way to close it :-)
    Thanks for all the tips. I hope that with this post I will help someone in the future to extract the grain from the chaff.
    Replacing the complete power system (PLN 20 with secure delivery included) helped.
    The winner is KRY5PIN: - )
The discussion revolves around a Lumia 535 experiencing charging issues despite the charger being functional with other devices. The user initially suspected a damaged USB port but confirmed voltage presence at the USB output. Responses suggest measuring the charging current and replacing the USB connector, as it is a common issue with this model. Some participants recommend checking the voltage reaching the motherboard, indicating that the problem may not solely lie with the USB connector. The conversation emphasizes the importance of thorough diagnostics before replacing components, as the fault could be elsewhere in the device.
