ZTE MF283+ Router: Best External Antenna for LTE 800 Band & Affordable Access Point Options
koki312 7734 5
  • #1 16571376
    koki312
    I have a ZTE MF283 + router (Lte from Orange). Unfortunately, there are coverage issues. The transmitter is located at a distance of about 4 km and broadcasts on the 800 band. I plan to buy an external antenna and mount it on the roof and move the router to the attic. Could you advise me which antenna (and antenna cable) to buy for this router. Because the devices in the home are out of the range of the Wifi network, if the router is in the attic, I also need to purchase an access point. Can you choose something for less than PLN 200?
  • #2 16571431
    matek451
    Help: 4352
    Rate: 5808
    Why a router in the attic? You buy an antenna and set the router in an optimal place. If you need an additional AP, you connect with MF283 + to a LAN-LAN router, e.g. WR-841 and configure it as an AP, it is a better and cheaper option than buying an expensive AP. What are your signal parameters now, how do you know that you connect to LTE800 Orange and with which BTS?
  • #3 16572124
    koki312
    I can mount the antenna only on the roof or on the balcony, while devices that will be connected to the network are located on the lower floors of the building. I figured it out so much better to pull a twisted pair cable than an antenna cable.
    Ok then this issue is solved.
    I received this information on the Orange helpline.
    As for the signal quality. It is often the case that I don't have Lte at all but HSPA +.
    Below are the parameters from the 3WG3-WATCH program:
    ZTE MF283+ Router: Best External Antenna for LTE 800 Band & Affordable Access Point Options2017-07...png (12.22 kB)You must be logged in to download this attachment.
  • #4 16572137
    matek451
    Help: 4352
    Rate: 5808
    You have 4 km to BTS LTE800 Orange in Zdziechowice Drugie, router at home, in the attic? Poor signal parameters, what speeds? On how many floors do you want to get WiFi coverage?
  • #5 16572358
    koki312
    Exactly so Zdziechowice Drugie. Router parameters given at the moment when it is at home. Later I will move the router to the balcony and give the parameters.
    ZTE MF283+ Router: Best External Antenna for LTE 800 Band & Affordable Access Point Options2017-0..png (38.02 kB)You must be logged in to download this attachment.
    If the antenna were on the balcony is only one floor but I would need a cable at least 15 meters between the antenna and the place where I now have a router.
    Edit.
    Parameters and speeds when the router is on the balcony.
    ZTE MF283+ Router: Best External Antenna for LTE 800 Band & Affordable Access Point Options2017-07-..7.png (11.93 kB)You must be logged in to download this attachment.
    ZTE MF283+ Router: Best External Antenna for LTE 800 Band & Affordable Access Point Options2017-07-..7.png (37.1 kB)You must be logged in to download this attachment.
