Understanding TP-Link RE450 WiFi Amplifier Functions: RJ-45 Cable Input & Signal Enhancement
Kamil1919190 6330 9
  • #1 16576754
    Kamil1919190
    I have a WiFi amplifier TP-Link RE450 and I have such a question because because there is an RJ-45 cable input in the device, I wonder how it works or if I connect the RJ-45 cable directly, will there be a better WiFi signal?
    jimasek
    Help: 3783
    Rate: 2677
    The RJ45 socket is to use the network (have access to the Internet) wired. You can then connect to the TV socket or any tower that does not have a wireless card and stands far from the main router. This has nothing to do with the range of this device.
    The principle of the amplifier's operation is, as the name implies, the wireless network gain from a device that does not have the range we need. The repeater receives the signal from the main wireless router and then transmits it, extending the range of the wireless network in the house / apartment.
  • #3 16576782
    Heinzek
    Help: 554
    Rate: 494
    The repeater can also act as an AP when connected to the router via a LAN port.
  • #4 16576803
    Kamil1919190
    What does AP mean because I'm a little off topic?
  • #5 16576810
    Heinzek
    Help: 554
    Rate: 494
    AP is an Access Point. Access point.
    Today's routers with wifi are nothing but router + switch + AP
  • #6 16576816
    Kamil1919190
    Oh, or how well I understood this, how to connect the router to this amplifier will work as an access point, i.e. it will increase my WiFi range, yes?
    Heinzek
    Help: 554
    Rate: 494
    More specifically, a new wifi point will be created. If you call it the same as the main network + the same key, you will automatically connect to the new point.
  • #8 16576835
    Kamil1919190
    Oh, that's what I meant. It would be enough in this topic thank you for your help.
    Best wishes :-)
  • #9 16576843
    jimasek
    Help: 3783
    Rate: 2677
    Configuration as Access Point then because you have the Range Extender option in the menu.
  • #10 16576853
    Kamil1919190
    OK, I was talking about a new access point because currently I have poor WiFi coverage, the amplifier is too far from the router, so I have to connect it with an RJ-45 cable. Thanks again for your help. Subject to close.
✨ The TP-Link RE450 WiFi amplifier features an RJ-45 cable input that allows it to function as an Access Point (AP) when connected to a router via a LAN port. This setup enhances WiFi coverage by creating a new wireless access point, effectively extending the range of the existing network. Users can connect devices that lack wireless capabilities directly to the RE450 using the RJ-45 port, but this connection does not improve the amplifier's signal range. Proper configuration allows the RE450 to replicate the main network's SSID and password, facilitating seamless connectivity for devices within its range.
