Baofeng UV-82: Programming Frequencies & Channel Names via Keyboard Without PC Cable
mcezar 25530 12
How can I program frequencies and channel names on a Baofeng UV-82 using only the keypad, without a PC cable?
You can program frequencies from the keypad using the UV-82 manual, but you cannot enter channel names directly from the radio; that naming option is available in the PC programming application instead [#16584119] [#16584587] [#16586193] One reply linked the UV-82 PDF manual for step-by-step keypad programming [#16584119] Another reply stated that channel names cannot be set from the “finger”/keyboard on the radio [#16584587] The thread also says the application supports this feature and that the UV-82 had been programmed that way before [#16586193] A download page for the software was provided, but the application is not in Polish; only a shortened Polish instruction was mentioned [#16588157] [#16588260]
  • #1 16580124
    mcezar
    Rate: 19
    Hello, I have baofeng uv-82. I decided to buy and as it turned out I bought blocked. My colleague decoded them and told me to tire myself further ... And I have been sitting for 3 days and I can not figure out what's going on. I want to program on the frequency data. Can someone explain me step by step how to program this device, unfortunately I do not have a PC cable and only the keyboard remains?
    is it possible to program eg: instead of frequency, the name of the channel will be displayed? e.g.: communal channel?
  • #3 16584523
    mcezar
    Rate: 19
    buddy but nowhere is it written whether you can give the name of the channel instead of the displayed frequency [/ video]
  • #4 16584587
    Interesant
    Help: 204
    Rate: 249
    If I remember correctly, you will not name it from your finger.
  • #5 16585583
    mcezar
    Rate: 19
    Well, I know, but can I do it on a pc? Can you do it at all?
  • #6 16586193
    Interesant
    Help: 204
    Rate: 249
    The application has such a possibility and probably someone a few months ago I did UV-82.
  • #7 16588153
    mcezar
    Rate: 19
    and would you have this program?
  • #9 16588165
    mcezar
    Rate: 19
    no PL version
  • #10 16588167
    yes2mike
    Help: 258
    Rate: 322
    Well, please ... It's gone and it will not be. Unless someone wants to translate from English.
  • #11 16588184
    mcezar
    Rate: 19
    well, how will I buy it on the famous auction site, it will be in the pl version? or not?
  • #12 16588260
    Interesant
    Help: 204
    Rate: 249
    Application or instruction ??
    Application - No.
    Instructions in Polish but shortened - Yes
  • #13 16590084
    mcezar
    Rate: 19
    thanks, subject exhausted
✨ The discussion revolves around programming the Baofeng UV-82 radio without a PC cable, focusing on how to input frequency data and display channel names instead of frequencies. Users share resources, including a programming guide, and discuss the limitations of programming directly via the device's keyboard. It is noted that while the application can facilitate naming channels, a Polish version of the software is not readily available. The conversation concludes with the acknowledgment of the topic being exhausted.
