Which cables to connect the sliding gate operator and the video entry phone
Asphyxx 57192 5
  • #1 16580888
    Asphyxx
    Rate: 8
    Good morning,
    At the moment I'm flooding the fence in front of the house and I need to lead the wires to the drive and to the video door entry with the electric lock,
    I have a question, do I need to feed only an earth supply cable - eg 3x 1.5 mm2 - to the sliding gate operator (surely the FAAC 740 will be - 350 Watt)? and only from the drive will the individual cables go, for example to the lighting of the signaling lamp and photocells?
    The same question applies to the video intercom.
    Here I saw that the electrician also gave me a ground wire consisting of 8 thin wires (probably just to the video door entry) - so I have to bring only his, or additionally the power cord?
    I am asking for advice.
  • #2 16580909
    aaanteka
    Help: 729
    Rate: 1194
    If somebody is already carrying out the installation, why not ask this person or rely on her experience? Generally the main question is, will you be the one who assembles everything, will it be done by the assembly company?
    The way you lead, the number and type of wires depends on the device model used (as you perceived), as well as distance and terrain conditions.
  • #3 16580919
    Asphyxx
    Rate: 8
    The point is that I do not have contact with him, and even if he was - it would take a few days to get upset, not for weeks.
    The distance of the cable to the sliding gate is only about 5m. I understand that the YKY 3x 1.5mm2 cable is enough? And the rest of the wires for the photocells and the signal lamp will be led directly from the drive?
    I have a cable to open the sliding gate with the button at home - I also need to drive it?
    And now regarding this unfortunate video intercom. The twisted pair should suffice for the video entry and the electric lock (8x wires)?
    In addition, both the cable for the electro-pick and the video doorbell with 12v voltage, and the sliding gate 230v?
    I am interested in such a video intercom - link
    There will be one monitor in the middle of the house.
    And answering the question - YES - I would like to mount it myself.
    aaanteka
    Help: 729
    Rate: 1194
    Here you have quite transparent video tutorials showing good solutions to the details of wiring.
    It's worth to see how others do it.
    It is wise to use the right pipe or PVC pipe, especially since the distance is small. This allows you to add additional cables or replacements in the future with little effort and resources.
    If you anticipate the use of a drive, where the electronics of the control unit is combined with the motor (one housing), then using a home button requires a separate wire to the button, according to the connection diagram of the drive.
    The indicated video model of the entry phone is an analogue set. Why in this case twisted pair? from practice, I suggest using shielded cables despite only 5 meters. It will be better to work without electromagnetic interference. It is most reasonable to buy such a model and check the functioning on the proposed wiring and shielded.
    Moderated By suworow:
    Please do not mislead the user. The "twisted pair" cable selected by the questioner is the correct one here, and whether the system is analog or "digital" has nothing to do with this.
    3.1.11. Do not send messages that do not contribute to the discussion. They are misleading, they are dangerous or they do not solve the user's problem.
  • #5 16581063
    krzysztofh
    Help: 101
    Rate: 937
    These types of installations are made with an earth cable resistant to external conditions. It is a mistake to use such cables in PVC pipes or conduits.
    It is worth checking to see if the coaxial cable is indicated.
  • #6 16582170
    andrzej lukaszewicz
    Help: 626
    Rate: 2122
    If they are resistant to external conditions, then putting them in a tube or DVR will not hurt them.
    The disadvantage of this solution is the collection of water in the pipe and probably this is what my friend is talking about. And often I cut the rure in the lowest place.
    I almost always carry cables under the entrance to the "other side" of the gate in the protective pipe or hard pipe.
    When laying the foundation of the gate it is worth to leave the passage (s) on the wires under the place of the drive assembly. I target a given device (pics, a lamp, an intercom) at this stage, I put in hard plastic boxes with a stainless steel remote control (or right away with appropriate cables) from the drive to the above devices.
    The cable for the video door intercom may also be passed through the drive housing - you can use the option of opening from the intercom.
    It is enough to power YKY3x1,5, unless you plan for an external socket. in the drive area it is 3x2.5. For intercom telephone cables, for example 5x2x0,5. Between the photos, the same or any low-voltage in the gel for laying in the ground min 4 or more veins.
