NAC YT5107 Lawn Mower: Guide to Pulley Removal, Rotor Bearing Collapse & Repair
barthek 11811 2
  • #1 16584334
    barthek
    Rate: 47
    I have a problem with a mower that performs well so far as in the title.
    The visual inspection shows that the rotor bearing has probably collapsed.
    How to remove the pulley in this configuration? Is it hammered? Screw in?
    Any tips are appreciated :)
    Czyżycki
    Help: 75
    Rate: 197
    The wheel is screwed in. The thread is probably right, i.e. unscrewing to the left. Hold the impeller towards the fan. Link
  • #3 16619491
    barthek
    Rate: 47
    Thanks for the tips!
    After unscrewing the pulley, the plastic of the fan should be gently lifted, then down the hill - two long screws, removing the brush holders and the whole business on top :)
    Two bearings 6001z and 627z scattered inside.
