Iveco Daily 35S13 2013: Steps to Dismantle the Middle/Supply Panel
Pieter125 18840 2
  • #1 16585203
    Pieter125
    Hello, how can I dismantle this panel in the subject? Iveco Daily 35S13 2013: Steps to Dismantle the Middle/Supply Panel the car was beaten maybe it will give some view on the situations of the cable I twisted and nothing helps to undermine on each side on the latches but it holds as if the middle and I can't find the screws anywhere because there are none or under the knobs no plugs help
    BiggSizze
    Rate: 62
    Remove the middle knob (it's from the airflow speed) there is a screw that holds the panel :)
  • Hidden screw under airflow knob and two base screws
    #3 21223816
    hans87
    Rate: 38
    After all these years, but maybe someone will find these tips useful.
    As a colleague above wrote - one screw is under the knob to adjust the airflow gear (set the knob to 2nd gear and pull hard towards you to pull it out).
    Then at the base of the panel you have another 2 screws (if they are obscured by something, e.g. radio, chiller control then you need to remove them to reach these screws.
    Once all 3 screws are removed, you can gently pull the panel from underneath and inside to remove it. And that's it :-) .
