Iveco Daily III 35C15 Timing - Diagram of engine timing setting 8140.43N
tomekk942 7209 1
  • #1 16585607
    tomekk942
    Hello, I need a timing diagram on the Iveco Daily 35C15. I have searched every page I can think of and found nothing. Thank you in advance for your help.
  • #2 16590510
    Dawid W
    Help: 8
    Rate: 88
    is it on a regular pump?
    The camshaft has a notch on the wheel, more or less vertically (you will see the second mark on the keyboard cover) pump for the drill, there should be a mark on the shaft and it probably goes down
