Xiomi Note 5A Prime: Selfie Stick Connectivity and Compatibility Issues
Alixia 7161 6
  • #1 17241354
    Alixia
    Rate: 16
    I have a selfie stick quite ordinary. So far, everything was fine. After connecting to the Xiomi Note 5A phone, it does not work :( you can not take a photo with any application. There is nothing in common. Does this type of camera need a special selfie stick? Maybe something needs to be changed in the phone settings?
    I am asking for advice :)
  • #3 17241520
    Alixia
    Rate: 16
    I have the usual one unfortunately - from the Chinese store, no bleutooth. It worked on previous phones and I even rented it to random people and it worked too ;) and it doesn't work here. I guess I'll have to buy the right one. I'll take a look at the link from you ;)
  • #4 17241526
    Pedros050
    Help: 2471
    Rate: 3926
    It would be appropriate to buy the right one for the phone.
  • #5 17241532
    Alixia
    Rate: 16
    I change phones so often that there would be a nice collection of these poles ;)
    Well, if this one is really dedicated to the redmi note 5a phones, I will have to buy it ;) oh :) unless I test a few in a Chinese store again and some will work ;) And there's nothing else you can do here? Only a stick with bluetooth?
  • #6 17241544
    Pedros050
    Help: 2471
    Rate: 3926
    It is best to check if it works in the store.
  • #7 17241683
    Alixia
    Rate: 16
    So I will! Thank you :)
The discussion revolves around connectivity issues between a standard selfie stick and the Xiaomi Note 5A Prime smartphone. The user reports that their ordinary selfie stick, which previously functioned with other phones, fails to operate with the Note 5A. Responses suggest that the selfie stick may require Bluetooth compatibility, which the user's current stick lacks. Recommendations include purchasing a dedicated selfie stick designed for the Xiaomi Note 5A or testing various models in a store to find one that works.
