Renault Master 2.3 dci 146 km - Renault Master power drop at low temperatures
Pawel88reno 15084 14
Why does a 2012 Renault Master 2.3 dCi 146 hp lose power below about 4°C or in fog, with higher fuel consumption, despite a new battery, filters, and no fault codes?
The thread points first to a sticking or poorly closing EGR valve as the most likely cause of the intermittent power loss [#16212220][#18538077] Compression should also be checked, because a compression problem can cause weak power even when the computer shows no errors [#16221305][#16224831] Several replies note that no fault codes do not rule out a real mechanical issue, so reading live measuring blocks with Renault Clip was suggested instead of relying only on a basic scan [#18539337][#18539347] The earlier DPF removal did not solve the problem, so the fault is probably elsewhere in the engine air/exhaust control or engine condition [#16212834][#16237186]
  • Power loss below 4°C persists after battery and filter replacement
    #1 16208102
    Pawel88reno
    Hello. As the topic . Master loses power at about 4 degrees and below and during fog it is even worse. First of all, because the car has already been driven a lot, I removed the DPF filter so I was told but it did not give any results. After returning from the route, I took the car to the Renault service there, I was told that the battery is completely dead and this could be the reason because even while driving it did not land properly and had voltage drops. It seemed a little unlikely to me but Ok. I put a new battery stronger and the problem remained. I decided to disappoint the car in a different place (service with many good reviews), they checked the turbine and said it was Ok, there was not the slightest error in the injection, so I did not decide to check it on the machine because it was expensive and the service's assurance said it was not 99% . They only replaced the fuel and air filter, but it didn't help either.
    Help please
    Instead of smoking 10l, it can 14-15l per hundred at 90 km / h
    Year 2012 2.3 dci 146 km
    klimosz
    Level 19  
    Help: 25
    Rate: 119
    Thinking mechanics and electronics, cut ... the best. Fast money earned and spent at the same time.
    These days are passing, now they will put it back.
    I would check the correct operation of the EGR valve, which can give the effects you describe if it has problems with closing.
    He checked NOT cut :)
  • Power loss appears under load after gentle driving
    #3 16212834
    Pawel88reno
    Thank you for the hint.
    I will definitely check how I will have the opportunity. As for DPF, it wasn't a hint from the mechanic who cut it out for me. The only thing he said is that the filter is very clogged and can cause a slow power, so I decided to get rid of it.
    Since replacing the battery and filters, I did 1500km and the car seemed to go normally and the temp sometimes -20 ... I don't know what hurts it anymore.
    I also noticed that as if after driving I go gently to 90 km / h there is no problem but when it comes to get up the hill and start adding more gas then the car weakens and I have to reduce sometimes to 4 for small driveways.
    Bunny82
    Help: 15
    Rate: 242
    And you checked the compression ??
  • #5 16224332
    Pawel88reno
    Personally not because I have no idea ... ;)
    As I wrote, the master went through two services including one authorized Renault and I have no idea if it was checked. I think not. I will add now that here probably the temp has nothing to do with the behavior of the engine. At -20 the car sometimes goes normally sometimes it doesn't go ... More and more people tell me to take care of this EGR valve.
    However, I am interested in one thing. Why did nobody even think in both services that this could be the cause of problems ...
    Someone will recommend a mechanic / service in Poznań and vicinity where I can give my car to check this EGR?
  • Intermittent power loss may indicate an EGR fault, not temperature
    #6 16224831
    Bunny82
    Help: 15
    Rate: 242
    Because the name Authorized service does not necessarily mean that professionals work there. If you do not have the basics of the concept of "compression measurement", put the car in the workshop and let them do it to you because you will spend more money on such a donation "or maybe it was because someone told me, or maybe now" You were on a computer? one can deduce a lot from the parameters, if anyone has an idea, are there any errors?
  • #7 16225912
    genek1000
    Help: 289
    Rate: 1057
    This is the best. Now a horse with a row to who gets what's going on after removing part of the program. Anyone thinking about the flow ???
  • #8 16237186
    Pawel88reno
    There's nothing under the computer. Totally no errors. Maybe I made a mistake with this dpf but if the car still goes sometimes good sometimes bad it probably was not a problem. I will be in Poland, I will check the compression and this egr.
  • #9 18537596
    Stalin88
    Rate: 15
    Is there a solution to this?
  • #10 18538077
    walek8
    Rate: 201
    Hello, I would check the EGR valve - it is possible that it is cut in a given position and this gives the effect of the engine work.
    Regards
  • #11 18539265
    Stalin88
    Rate: 15
    It would be a mistake and nothing here
  • #12 18539337
    walek8
    Rate: 201
    What is this diagnosed? Can I do diagnostics with Clip?
  • #13 18539347
    Stalin88
    Rate: 15
    I have no power after replacing the engine all the time. 90km to achieve is success. The injections are the same. Only the bar is new.
    There are no errors. The measuring blocks were read by such a magician and sent to a Renault service. They said everything is ok. The car still does not drive. Some tragedy. I used to ride 140 an hour on it
  • #14 18543595
    walek8
    Rate: 201
    Maybe try to lose soft.
  • #15 18766138
    walek8
    Rate: 201
    And you know something about the subject?
The discussion revolves around a Renault Master 2.3 dci 146 km experiencing a power drop at low temperatures, particularly around 4 degrees Celsius and during fog. The owner has removed the DPF filter, replaced the battery, and had the vehicle serviced at two different locations, including an authorized Renault service, but the issue persists. The vehicle consumes more fuel than usual, and the owner suspects the EGR valve might be malfunctioning, as it has not been checked thoroughly by the services. Other suggestions include checking the engine compression and ensuring proper diagnostics are performed to identify any underlying issues.
