Peugeot 207 1.6 VTi 2008 - Engine Stalling, Starting Issues, Variable Valve Timing & Error Codes
marekfiesta 28953 16
How do I initialize and set up the valvetronic motor on a 2008 Peugeot 207 1.6 VTi after replacing the motor and sensor, when P101A and P1025 remain and learning fails?
Set the valvetronic motor halfway between its end positions, then run the adaptation/initialization with a diagnostic computer; if the mechanism is mechanically correct, it should work [#20515748] [#20535221] One reply also says to look for the telecoding parameter in the ECU/diagnostic settings to finish the setup [#21123012] If the fault still comes back, check the timing chain too, because these engines commonly suffer from chain stretch [#16901898]
  • #1 16901887
    marekfiesta
    Level 19  
    Help: 16
    Rate: 323
    As in the title, the car came with the problem of stalling the engine at idle and no possibility of starting the engine, the pride of the fuel. Proxia errors connected P1030 and 1062 wrong setting of variable phases, I decided to replace the motor and the valvetronic sensor, these errors are gone but P101A and P1025 appeared learning no learning. I did a step-by-step initiation of a new equipment but could not do it. Maybe someone encountered such faults. Peugeot 207 1.6 16V vti 2008.
  • #2 16901898
    milejow
    Help: 1563
    Rate: 5149
    marekfiesta wrote:
    I decided to replace the engine
    There is no such thing, but there are commonly extending chains
    Działalność własna
    Mętów 99, Lublin, 20-388
  • #3 16901916
    marekfiesta
    Level 19  
    Help: 16
    Rate: 323
    unfortunately, but it is controlled by a motor with a variable valve lift system
  • #4 16901959
    milejow
    Help: 1563
    Rate: 5149
    marekfiesta wrote:
    variable valve lift
    Angular displacement of the shaft and not lifting of the valves.
    Działalność własna
  • #5 16901981
    marekfiesta
    Level 19  
    Help: 16
    Rate: 323
    VDO variable camshaft adjuster A2C59515108 here is the engine number which regulates valve height bmw and mini design
  • #6 19142565
    kubas10
    Help: 42
    Rate: 1547
    Can you tell how this valvetronic motor is assembled? I replace the motor and have to move it to the other one.
  • #7 19143185
    chiki-chan
    Rate: 11
    motor normally no philosophy there then adaptation
    this vti is a river topic or you have a howl ... a chain or a head and it can also be a roller
    as well as everything at once
  • #8 19143215
    kubas10
    Help: 42
    Rate: 1547
    And what is the position of this intermediate shaft?
  • #9 19144884
    kubas10
    Help: 42
    Rate: 1547
    Turning the roller valvetronika 4 teeth from position 0 goes correctly, I understand correctly?
  • #10 19185952
    kubas10
    Help: 42
    Rate: 1547
    If anyone has a problem with this, the matter is simple, please contact me on priv. Everything flashes for me. What I wrote earlier is wrong.
  • #11 19394571
    yack2
  • #12 19395095
    kacu-55
    Rate: 8
    Can you tell me how to set it up properly?
  • #13 19925743
    coperfild
    Help: 291
    Rate: 1697
    Can someone write how to set this motor relative to the shaft, is it some kind of secret.
  • #14 20515742
    albertem
    Is this motor set relative to the fight?
  • #15 20515748
    kubas10
    Help: 42
    Rate: 1547
    Yes, it's supposed to be halfway done.
  • #16 20535221
    coperfild
    Help: 291
    Rate: 1697
    As everything works, just make settings with a computer and it should work.
  • #17 21123012
    diagautob27
    Rate: 18
    find i telecode parameter
The discussion revolves around the issues faced with a 2008 Peugeot 207 1.6 VTi, specifically engine stalling at idle and starting difficulties. The user initially encountered error codes P1030 and P1062 related to variable valve timing, which were resolved after replacing the motor and valvetronic sensor. However, new error codes P101A and P1025 emerged, indicating learning issues. Participants in the forum discussed the variable valve lift system, the assembly of the valvetronic motor, and the importance of proper adaptation and settings. Several users shared insights on the positioning of the intermediate shaft and the necessity of using a computer for settings adjustments to ensure proper functionality.
TL;DR: A 17‑post thread (2017–2024) traces Peugeot 207 1.6 VTi stalling and no‑start to VVT/valvetronic setup and adaptation; “I decided to replace the motor and the valvetronic sensor.” [Elektroda, marekfiesta, post #16901887]
Why it matters: This FAQ helps DIYers and techs fix rough idle, stalling, and fault codes after valvetronic/VVT work on the 1.6 VTi.
What do codes P1030, P1062, P101A, and P1025 mean on a 1.6 VTi?
They indicate variable valve timing/valvetronic issues and failed learning. On this engine, they appeared with stalling and no‑start. Replacing the valvetronic motor and sensor cleared P1030/P1062, but learning errors P101A/P1025 remained until proper setup and adaptation. [Elektroda, marekfiesta, post #16901887]
How do I position the valvetronic motor before adaptation?
Set the actuator to a mid/halfway position relative to the mechanism, then perform electronic adaptation with your diagnostic tool. This prevents end‑stop binding and failed initializations. As one tech notes, “Yes, it's supposed to be halfway done.” [Elektroda, kubas10, post #20515748]
Do I need to run adaptation after changing the valvetronic motor?
Yes. Install the motor correctly, then run adaptation in Proxia/DiagBox. Users report that after correct mechanical setup, software settings complete and the system works normally. Skipping this step leaves learning errors. [Elektroda, coperfild, post #20535221]
Is chain stretch a known cause of rough idle or stalling on the 1.6 VTi?
Yes. Mechanics in the thread flag the timing chain as a commonly stretching component. Chain elongation upsets cam phasing, which can mimic or worsen valvetronic faults, leading to idle instability. Inspect chain condition before repeated adaptations. [Elektroda, milejow, post #16901898]
Which actuator part is referenced for this engine?
The thread cites a VDO variable cam/valve lift adjuster, part A2C59515108, used in BMW/Mini‑derived systems. Matching the correct unit is critical before attempting adaptation or telecoding. [Elektroda, marekfiesta, post #16901981]
How is the valvetronic motor assembled—any trick to it?
Assembly is straightforward: fit the motor, align it correctly, then run adaptation. A contributor summarizes it as “motor normally no philosophy there then adaptation.” Ensure mechanical timing and chain condition are sound before software steps. [Elektroda, chiki-chan, post #19143185]
What about the ‘4 teeth from position 0’ tip—should I use it?
No. The author later retracted that guidance and confirmed it was wrong. Treat any fixed‑tooth rotation advice with caution; use the halfway positioning plus proper adaptation instead. This prevents misalignment and repeat errors. [Elektroda, kubas10, post #19185952]
Does the motor position relate to the intermediate shaft or cam?
Yes. Users asked specifically about the intermediate shaft position. The reliable guidance is to set the valvetronic mechanism to its halfway travel relative to the shaft before adaptation. This centers the range for learning. [Elektroda, kubas10, post #20515748]
What tool or menu do I need for telecoding/parameters?
Use your PSA tool (Proxia/DiagBox) to find the relevant telecoding parameter and execute the guided learning procedure. Telecoding ensures the ECU recognizes the actuator’s position and limits after installation. [Elektroda, diagautob27, post #21123012]
Could a cylinder head or roller issue also cause these symptoms?
Yes. A tech notes the VTi can suffer chain, head, or roller faults—sometimes more than one at once. Diagnose mechanically first, then perform adaptation; software will not mask hard faults. [Elektroda, chiki-chan, post #19143185]
What is valvetronic on the 1.6 VTi?
It’s a variable valve lift system actuated by an electric motor and mechanism. The cited VDO A2C59515108 adjuster changes valve lift, working alongside cam phasing for efficiency and idle control. [Elektroda, marekfiesta, post #16901981]
What is Proxia/DiagBox in this context?
They are PSA diagnostic suites used to initialize, adapt, and telecode components. After correct mechanical setup, running adaptation in the software restores proper idle and starts. “As everything works, just make settings with a computer.” [Elektroda, coperfild, post #20535221]
How do I perform a quick adaptation after replacing the motor?
  1. Set the valvetronic mechanism to its halfway position and install the motor.
  2. Verify timing chain condition and base timing; correct if off.
  3. In Proxia/DiagBox, run the valvetronic learning/adaptation procedure to completion. [Elektroda, coperfild, post #20535221]
Why do learning codes persist after replacing parts?
Learning fails if the mechanism isn’t centered, timing is off, or the chain is stretched. Replace parts only after confirming base timing and then re‑run adaptation. Part swaps alone won’t clear learning errors. [Elektroda, marekfiesta, post #16901887]
Any edge cases I should watch for during setup?
Avoid fixed ‘tooth count’ positioning advice. One user proposed a 4‑tooth offset, then withdrew it as incorrect. Use the halfway method and software learning instead to prevent damage and repeat faults. [Elektroda, kubas10, post #19185952]
Does software alone fix stalling without mechanical checks?
No. Contributors stress verifying the chain, head, and rollers first. Only then will adaptation succeed and stalling resolve. Software cannot compensate for worn mechanical components. [Elektroda, chiki-chan, post #19143185]
