Satel Perfecta Alarm System with SL550 Siren: LED Flashes Constantly After Installation
cygowski 8157 2
  • Need to check SL550 siren wiring and tamper loop
    #1 16592046
    cygowski
    I have a problem with the alarm system. I made the installations myself. Everything works fine, but I have a problem with the siren. After connecting the power supply to the control unit, the LED from the siren flashes all the time. Satellite perfecta control unit, SL 550 signaling device. I read all the forum topics and did not find a solution. I took the connection diagram from the forum Satel Perfecta Alarm System with SL550 Siren: LED Flashes Constantly After Installation
    Will someone help and tell where I have the error?
  • #2 16592062
    dariusz.bembenek
    Stationary Alarms specialist
    Help: 455
    Rate: 615
    The SP550 is a satellite journey. Documentation available on the Internet. How did you connect it at this point? Upload your connection diagram and then you can keep talking.
  • #3 16592091
    cygowski
    I have included the diagram in the post. Connection is the same as in the picture.
    Any idea?
    Advertisement
    Also read:
    Satel Perfecta alarm control panel, configuration - selected issues Collection of topics
    Outputs (programmable and not only) of control panels
    How the control panel alarm outputs work
    Connecting any detector to any alarm control panel - guide
    How to connect the siren to the alarm control panel - guide
    We invite you to read the other guides, highlighted topics, articles in the field of security systems such as intercoms, gate and barrier automation, alarm systems, cameras, access control:
    Security Systems Tutorials
    If the above-mentioned topics do not find an answer to your question, please visit the forum
    Security systems
    We also encourage you to visit the General Guides section, where you will find materials from other forum sections, including those for people starting their adventure with electronics:
    General Tutorials
