Title: Disabling Power Failure Sounds on Satel Perfecta Alarm with PRF-LCD Keypad
msikorski 33690 7
  • #1 18463616
    msikorski
    Hello and welcome,
    I am asking for help from experienced users of the Satel Perfecta alarm with the prf-lcd keypad.
    I live in a housing estate in the middle of a forest, which is not only built quite intensively, but is also exposed to extremely frequent power failures due to weather conditions. Power outage happens at least a few times a month and with the weather we have now it is, for example, yesterday 2 times at night, today 2 times at night. When there is a power failure, the manipulator squeaks so loud that the whole house is put on its feet and I have to specially get up, go downstairs, delete the failure.
    My question - how do I turn off the power failure keypad sound? All I need is a phone notification and a flashing LED. Thanks for the help in advance.
    Announcement
    We invite you to familiarize yourself with guides, highlighted topics, articles in the field of security systems such as intercoms, automatic gates and barriers, alarm systems, cameras, access control:
    Security systems guides
    If you do not find the answer to your question in the above-mentioned topics, please visit the forum:
    Security systems
    We also encourage you to visit the General Guides section, where you will find materials from other sections of the forum, including those for people starting their adventure with electronics:
    General Guides
  • #2 18463720
    bhtom
    Help: 446
    Rate: 605
    What does the manual say about this? friend read?
    Regards.
  • #3 18465427
    msikorski
    Hello, I read that and unfortunately I can't read it. I only found information on how to turn off the sound once a failure takes place and the whole house is awakened by this beeping. I don't know how to disable this type of signaling. All I need is an SMS notification and a flashing LED. Hence my question here.
    Ps. You can't know everything mate :)
  • #4 18465462
    sosarek
    Help: 9321
    Rate: 15553
    In the keypad settings, you can set the volume for various actions - keep trying ;)
    Z
    Pka, Poznań, 60-850
  • #5 18465579
    msikorski
    The user manual does not mention anything about this. Are you sure about what you're saying or do you think so?
  • #7 18465657
    msikorski
    Ok, I see I have a slightly different problem at the moment. I can't get into service mode at all. The user menu is missing options number 7 and 8. Unfortunately, I do not know any other password that would activate the service mode option in the menu. The installer who set up the alarm probably kept this knowledge to himself. Is there anything else I can do in this direction or would it be best to call the installer to set it up?
The discussion revolves around disabling the loud power failure sounds on the Satel Perfecta alarm system equipped with a PRF-LCD keypad. The user experiences frequent power outages and seeks a solution to silence the keypad's beeping during these events, preferring only SMS notifications and a flashing LED indicator. Initial responses suggest checking the user manual and adjusting keypad settings, but the user reports difficulties accessing service mode due to missing options. The conversation concludes with a recommendation to contact the installer for further assistance.
