Re: FastSearch nbox Enigma2 - Uploading via Pendrive, Transponder Activation, NC+ Channel Update
brochmen 8511 7
  • #1 16767126
    brochmen
    Hello, I would like to ask if it is possible to upload to an nbox decoder with Enigma2 FastSearch with a pendrive? if so how do you do it? I am completely green in these topics, my problem is that with a fast channel search, the message transponder activation incorrect appears. I would like to update my nc + channel list. Thank you in advance for your help
  • #2 16767168
    KIEROWCA_VW
    Help: 273
    Rate: 676
    It is possible to copy files from a flash drive to the decoder memory. It will be easier and faster to use LAN.
  • #3 16768890
    brochmen
    Hello, when it comes to LAN, do you need to use any additional software ???
  • #4 16769088
    KIEROWCA_VW
    Help: 273
    Rate: 676
    Total Comander, WinSCP, DCC - helpful programs.
  • #5 16771094
    brochmen
    Unfortunately, after connecting the decoder via a LAN cable nothing happens
  • #6 16779643
    vito007
    Help: 73
    Rate: 216
    You need to know the decoder's IP address and connect to it using some ftp client (e.g. filezilla)
    jmjp
    I suggest total commander connected via wifi - ftp connection. You enter the decoder's ip address there, login and password are mostly root and pointeam, dreambox. A new fast search is included in the attachment with instructions on how to upload - in general, the procedure will take about three minutes with restarting the enigma.
    • tcmd852ax32.exe (3.62 MB) You must be logged in to download this attachment.
    • FastSearch.rar (8.39 KB) You must be logged in to download this attachment.
    • Czytaj.txt (129 Bytes) You must be logged in to download this attachment.
  • #8 16948738
    brochmen
    Hello, thank you very much for your help, everything works as it should be greeted
The discussion revolves around uploading files to an nbox decoder running Enigma2 FastSearch using a pendrive and addressing issues with transponder activation errors during channel searches. Users confirm that files can be copied from a flash drive to the decoder, but using a LAN connection is recommended for efficiency. To connect via LAN, users need to know the decoder's IP address and utilize FTP clients like Total Commander, WinSCP, or FileZilla. Instructions for a fast channel search update were provided, and the author confirmed successful implementation after following the guidance.
