Renault Grand Scenic 2005 1.9d - Replacement for the parking brake motor
p 14217 10
What replacement can I use for the Johnson 12V 73677 3K4812-05C parking brake motor, and where can I find it?
Yes — this motor is also sold under the part number 2214302949, has 17 teeth, is used in parking/hand brakes of several car brands, and can be found on AliExpress [#21854562] If you are looking for a used replacement instead of a new one, the thread suggests checking OLX and repair workshops/scrap units, since broken parking brake assemblies are often available there [#16600156]
  • #1 16599870
    p
    I am looking for a replacement for the Johnson 12V 73677 3K4812-05C motor, which is installed in automatic parking brakes.
    I'm having trouble finding the specifications for this motor. Is it possible to choose a replacement from another brand based on the same dimensions and on a 12V voltage?
  • #2 16600156
    Strumien swiadomosci swia
    Help: 1405
    Rate: 6433
    Take an ask after olx and the workshops of the broken one in bunches in May I threw 10 of them for scrap.
  • #3 16603091
    p
    Ok, I dismantled the brake and it turns out that the electronics are ok - but I am looking for a shaft (photos). Maybe someone has one :)
  • #4 16603149
    seat21
    Help: 151
    Rate: 399
    I have, if a friend is interested, pw
  • #5 16603281
    p
    Sure, if someone has something - please send PM. I am happy to consider offers
    @ seat21 I sent PW
  • #6 16638953
    krzysiek-blaz
    Rate: 12
    Hello. I need a Johnson 73677 motor for the scene. Anyone to sell at a reasonable price? Everything else works only the engine burned out. : /
  • #7 16828792
    bb.jj
    Rate: 19
    I think I will also need this motor, priv proposals
  • #8 17277159
    dymek81
    Rate: 17
    Also looking for this engine, does anyone have such a miracle?
  • #9 17445472
    tadeuszcz
    I need such a motor 73677 3E0813 for the Scenic II parking brake. Do any of you know where to buy it?
  • #10 17451674
    bb.jj
    Rate: 19
    I was sending a friend, unfortunately I could not find it
  • #11 21854562
    goranz
    that motor goes by the name 2214302949, has 17 teeth, is used in the hand brakes of several car manufacturers and can be found on Ali Express
Discussion about replacing the 12V Johnson motor used in the Renault Grand Scenic 2005 1.9d automatic parking brake. The original request asks whether a substitute from another brand can be selected based on matching dimensions and voltage. Later posts shift toward repairing the parking brake actuator by dismantling it and looking for a replacement shaft or complete motor assembly. Several participants report needing the same Johnson 73677 motor for Scenic parking brakes, while a later reply identifies an alternative designation, 2214302949, with 17 teeth, used in parking brake systems of multiple car brands and available from AliExpress.
