Renault Laguna III automatic manual brake does not release automatically
cineek88 30417 3
  • #1 16804569
    cineek88
    Rate: 9
    I have a technical problem. I have Renault Laguna III 2.0 dci 150HP.
    After automatic (or manual) pressing of the automatic hand brake it can not be automatically (after clogging the clutch and adding gas). The second problem is that rear parking sensors and reversing lights do not work for me. can these three issues be related? on the website I found out that all these things can combine one sensor?
    please help
  • #2 16804603
    leonov
    Help: 1039
    Rate: 2248
    It may be related to reversing sensors with reversing light (reverse gear sensor), but the handbrake has nothing to do with this. ;-)
  • #3 16804606
    andrzej20001
    Help: 1578
    Rate: 6669
    Gear position sensor. Renault Laguna III automatic manual brake does not release automatically
  • #4 16824275
    cineek88
    Rate: 9
    Problem solved. After replacing it with a new reverse gear sensor, everything returned to normal, i.e. the rear lights appeared, the rear parktronic and the electric hand brake started working well. Thanks for the help
