Romet Zetka Spark Issue: Seeking Solutions for Stator, Magnetic Pulser, Coil, Cables & Module
Robert100715 12438 11
Why does my Romet Zetka have no spark even after replacing the stator, magnetic pickup, coil, cables, spark plug and ignition module, and what else should I check?
Check the side-stand/side-foot kill switch first, because an open switch can cut the spark completely [#16602073][#16602495] If that is OK, verify that the stator and flywheel are a matched set and that the number of coils/poles and the pulser position match the magnetic wheel, because a wrong combination or an upside-down pulser can prevent ignition [#16602387] Also make sure the distance between the flywheel marker and the pulse generator is correct, not just that the parts fit mechanically [#16602387] To test the pulser, set a multimeter to continuity/buzzer mode, connect it to the pulse output, and slowly turn the crank/kick starter; the meter should beep when the pulser triggers [#16610076] Do not try to test it with 230 V, because that can shock you and burn the part [#16610076][#16610087] If the switch, matching, and pulser test out, the remaining possibility is a faulty replacement stator or pulse generator [#16602838][#16603306]
  • #1 16600897
    Robert100715
    Hi, help me because I have already doubted. I have such a problem that there is a lack of spark in the zetka I have already replaced the stator with a magnetic pulser new coil cables candle module still no spark. Installation good because I checked by connecting zetka to another moped. Assembled wires from stator from another moped to install and spark on the candle is. So I conclude that the installation as well as footers and other bullshit works, so I ask you what else may be wrong please help me because I have no ideas
  • #2 16602073
    rafcio_21
    Help: 137
    Rate: 299
    Detach the cables (ankle) from the side foot.
  • #3 16602387
    BANANvanDYK
    Help: 1167
    Rate: 2602
    When replacing the stator you may not have matched the number of coils to the number of poles of the magnetic wheel, while when replacing the magnetic wheel you may not have matched the distance at which the marker to the pulse generator is with the place where the pulse is located, the ignition angle could also change but then you would have a spark but you couldn't fire. You could also screw the pulser upside down.
  • #4 16602495
    tallellion
    Rate: 23
    Try to use the side foot to conclude that the spark is cut off if it is open, i.e. massages the module
  • #5 16602506
    rafcio_21
    Help: 137
    Rate: 299
    I have already written to the author to try to detach the foot cube only the author says nothing whether it worked or not I had two such cases with the foot.
  • #6 16602513
    tallellion
    Rate: 23
    A colleague in the Chinese scooter has the way he travels, when he vibrates, he unscrews and unscrews his foot sensor and goes out while driving and he has to screw every few km
  • #7 16602838
    Robert100715
    Sorry gentlemen, I could not write back, I checked the footer, and the wire that goes to the footer and nothing is the same, but I also checked with this impulse, you can screw it in one position only, and when it comes to matching the stator to the magnet, before buying a new stator I found out and also checked the magnet has a stator and magneto matched paired as it should be the foot certainly does not disconnect
    Added after 55 [seconds]:
    Any more ideas maybe someone will help something
    Added after 7 [minutes]:
    And I don't know if it could be that this new stator is damaged or the mass is silent or something, because I checked in another motor what is similar to the stator, how I measured the resistance, how I connected it with one cable from the meter to the stator cable and the other to the ground, it showed resistance new on the board complete any resistance I will mention on Monday a different stator from another store and we will see but if someone has any ideas what could be wrong, I will read with great pleasure and thank you for every little help
  • #8 16603306
    BANANvanDYK
    Help: 1167
    Rate: 2602
    In that case, please provide the results of stator and pulse generator measurements.
  • #9 16606553
    Robert100715
    Stator resistance is about 168 ohms and the stator I don't know exactly how to measure, I checked on other moto, there was resistance on each wire and the stator is only on one and it's weak
    Added after 6 [minutes]:
    Today I was in the store to find out and checked the meter with a different stator from the plug and the same resistance only on one wire now the question is whether it must be on one or all because I know that two wires connect with each other because they go from 3 coils and one on which resistance goes to the high voltage coil insulated fleece and not the spray insulation like the rest
    Added after 5 [minutes]:
    And now the question for you is how can I check the pulse generator because I know that I can check the resistance and put something metal or a magnet if it is good then the value on the meter will change and are there any other methods to check the stator and the pulse generator my colleague has told me today you can somehow check the stator by connecting it to 220 V but I don't know how if anyone would like to help, I would very much ask
  • #10 16610076
    BANANvanDYK
    Help: 1167
    Rate: 2602
    What pulser resistance?
    Do not connect anything under 230V, you will still get an electric shock.
    The operation of the pulser is difficult to measure (the best would be an oscilloscope), but there is a way to determine five times the door or the pulser is working - set the meter to the buzzer, connect to the pulse output, when the pulser generates a signal, there is a beep when slowly turning the shaft (kick).
  • #11 16610087
    rafcio_21
    Help: 137
    Rate: 299
    I also advise you not to connect under 230 V. First of all, the electricity can hurt you, and secondly you will definitely burn it.
  • #12 16610247
    Robert100715
    Oh thanks, I didn't know that
The discussion revolves around a lack of spark in a Romet Zetka after replacing several components, including the stator, magnetic pulser, coil, cables, and module. The user confirmed that the installation is correct by testing with another moped. Suggestions from other users include checking the alignment of the stator and magnetic wheel, ensuring the pulse generator is properly positioned, and verifying the functionality of the foot sensor. The user also inquired about measuring the resistance of the stator and pulse generator, with advice given on using a multimeter to check for signal generation from the pulser. The user reported a resistance of about 168 ohms on the stator and sought further methods to test the pulse generator.
