[Solved] Samsung S7 G930F - Softa-SW REV.CHECK FAIL DEVICE 2, BINARY 1 cannot be uploaded
Mementos 14136 4
  • #1 17297679
    Mementos
    Rate: 21
    I can't upload the software to G930F.
    I downloaded 9 different soft files from Z3X + 7 Combination support and unfortunately none come in:
    File analysis ... OK
    Total file size: 0x11353809B (4405 Mb)
    Searching USB Flash interface ... COM9 detected
    Setup connection ... OK
    Reading PIT from phone ... OK
    Sending sboot.bin ... OK
    Sending param.bin ... error timeout
    Done with Samsung Tool PRO v.32.7
    Before, the phone worked normally, I tried to reset the FRP and an error occurred during the flash ..
    sm233
    Help: 499
    Rate: 434
    You have binary 2 on your phone and you are probably trying to upload a software with bit: 1 and hence the error. First, download the combination of binary 2 or XXU2ARA2 or do FRP using a UFS cable and then you do not need to combine anything.
  • #3 17297777
    Mementos
    Rate: 21
    XXU2ARA2 also does not enter now, I have already done FRP after UFS, but I have not seen this solution before.
    Can you enter the software designation I need to upload?
    sm233
    Help: 499
    Rate: 434
    G930FXXU2ERE8 / G930FXEO2ERE8 / G930FXXU2ERD6 / G930FXXU2ERE8
    This is the designation of the latest software for the XEO market. Download it with SamFirm program, instructions are here on the forum.
  • #5 17297985
    Mementos
    Rate: 21
    The one you provided has uploaded, but the phone hangs on the pulsing SAMSUNG logo ... :(
    I uploaded COMBINATION + soft and the phone works! Thanks a lot!
