HP EliteBook 8460p USB 3.0 Ports Not Communicating: Installed Drivers, Checked BIOS, Windows 7
TimER12 8940 11
How can I fix USB 3.0 ports on an HP EliteBook 8460p that provide power but do not communicate with devices in Windows 7?
Install the USB 3.0 stack in the order HP recommends: first the NEC USB 3.0 Controller Firmware Update Utility, then reboot, then the Intel chipset package, reboot again, and finally the Renesas Electronics USB 3.0 Host Controller driver [#16601777] If Windows still shows no USB 3.0 controller properly, try cleaning old USB registry entries with DriveCleanup/DeviceCleanup and retest [#16601777] Check the BIOS for any XHCI/USB 3.0-related options and restore BIOS defaults if needed; if the menu does not show anything, inspect the hardware with USB Device Tree Viewer or AIDA64 to see whether the USB3 controller is detected at all [#16601777][#16601994][#16602792] A bootable Linux test is a good way to separate a Windows driver problem from a hardware problem: if USB 3.0 still does not work there, the controller may be disabled in BIOS or physically damaged on the motherboard/ribbon path [#16601772][#16601750]
  • #1 16601734
    TimER12
    Rate: 8
    Hello, I have an HP EliteBook 8460p laptop in which I have 2 USB 2.0 ports and 2 USB 3.0 ports. The problem is that on all ports it is so that I will capture the supply voltage but the USB 3.0 ports do not have communication (after connecting the pen drive or other device nothing happens).
    I have installed the drivers (the laptop is in use and there was a folder with all the drivers), I also checked in the BIOS if the ports are disconnected but everything was OK. After all, I disconnected the ports and turned them on again (it did nothing).
    I have Windows 7 Home Premium, additionally I downloaded from the HP website https://support.hp.com/pl-pl/drivers/selfservice/hp-elitebook-8460p-notebook-pc/5056942 the driver named Renesas Electronics USB 3.0 Host controller driver and reinstalled but it did nothing. I will add that the device manager does not display any drivers.
    Anyone know what I can do about it?
  • #2 16601750
    chrupek311
    In my opinion, this may be the motherboard's fault.
  • #3 16601752
    safbot1st
    Help: 2719
    Rate: 1585
    Run bootable linux from USB. Write if the ports below work correctly.
    I have already encountered the situation that, e.g. mouse or pen does not work for me in USB 3.0 (Lenovo), and in USB 2.0 it already does.
    It's hard to say if it's a childhood disease or drivers.
    List the options you have in the BIOS about USB. Maybe you can switch something there.
    I'm afraid it's the fault of this particular pen. Every now and then there is a situation that from one pen it is impossible to bet the system via USB 3.0, and on the other so. Such "PC magic". ; (
    Sure. :D And most of the fault is the USB standard from 2.0 to 3.0 ... ;)
    Added after 5 [minutes]:
    I found this "something":
    Switch. Write what effect.
    In total, the problem touches the tip of the UEFI iceberg.
    You would have to give us in what mode - emulation or UEFI - was the system put in place , it completely changes the way the "peripherals" communicate with the motherboard, And this is a problem in the subject!
    In the worst case (!) You will have to put the system back on . :(
    Ehh .. write what exactly you connect. There may also be a physical fault with the disc, as he wrote @ chrupek311 , but after "examining" PC with linux.
  • #4 16601771
    TimER12
    Rate: 8
    I checked the ports on 4 devices (2 flash drives, optical mouse and Arduino board) on USB 2.0, everything works while USB 3.0 works on Arduino but I can't communicate with it (I have power) and the mouse just lights up and goes out.
    And as for bootable linux from USB I have no idea what's going on (I don't know much about computers).
    In the BIOS I found something like this:
  • #5 16601772
    M4J3R0
    Install the chipset drivers. If that doesn't work then download some Linux (like Ubuntu), load it on a pendrive with Rufus and start your laptop by loading linux. If the USB ports still do not work, it may mean:
    - the controller in the BIOS is disabled. You can try to restore the bios to factory defaults. You can also update the BIOS.
    - controller released by connecting to the USB device of unknown origin
    - damaged path / ribbon due to unintentional disassembly of the laptop or falling.
  • #6 16601777
    safbot1st
    Help: 2719
    Rate: 1585
    TimER12 wrote:
    I have Windows 7 Home Premium, additionally downloaded from the HP website https://support.hp.com/pl-pl/drivers/selfservice/hp-elitebook-8460p-notebook-pc/5056942 driver named Renesas Electronics USB controller driver 3.0 Host and reinstalled but it did nothing.
    Maybe you don't have the driver installed. I found:
    under "Firmware" (for HP as usual, total mess, brrrr).
    ah, there is also your Controller Driver Renesas Electronics USB 3.0 Host under "Controller-Chipset".
    I suggest in this order:
    1 firmware upload
    2 reboot
    3 installation with "Controller-System kit" -> Intel chipset installation tool
    4 reboot
    5 installation from "Controller-System Kit" -> Controller controller Renesas Electronics USB 3.0 Host
    ... and how about linux?
    ps. It's nice as if you checked some Everest or ifa what chip on your board is responsible for USB 3.0. Please provide, because I have conflicting info from HP. Is it NEC or Renesas finally ...?
    Thanks to you I came across this:
    use @ TimER12 DriveCleanup program. He will clean registry entries and often unplug USB communication. I recommend:
    http://www.programosy.pl/program,drivecleanup.html
    Here you have e.g. Mint to download:
    https://www.linuxmint.com/download.php
    Do not write that you do not know about computers when it is only installed on a USB pen and sets UEFI to boot from USB.
    That's all. You are running linux. Run a USB 3.0 port test under it.
    Added after 4 [minutes]:
    At what standard is Arudino? The mouse also does not work as 3.0 probably and should be in 2.0 (does not change the fact that with 3.0 should work ;)
    It's an archaic "circus" BIOS from HP. Look for the XHCI and USB 3.0 options, show us all the tabs and that so that everything is visible and not cut.
  • #7 16601994
    pidar
    Help: 1569
    Rate: 3590
    Show us a screenshot of the program USB Device Tree Viewer .
    Well, I invite you to read -> my last " helped ". :idea:
  • #8 16602170
    TimER12
    Rate: 8
    Hello, I did everything with the drivers as safbot1st wrote, but it did nothing. In addition, I looked at the whole BIOS and found nothing related to USB 3.0.
    I started the USB Device Tree Viewer program:
  • #9 16602221
    pidar
    Help: 1569
    Rate: 3590
    You can't see, there are no USB3.0 drivers installed, or USB3.0 ports disabled in the BIOS :?:
    It's a pity, we won't check it anymore, you used it unconsciously on the recommendation of a colleague DriveCleanup instead DeviceCleanup what would I recommend now? :|
    http://www.uwe-sieber.de/misc_tools_e.html
  • #10 16602227
    TimER12
    Rate: 8
    As I wrote in the BIOS, I have not seen anything related to USB 3.0.
  • #11 16602792
    310artur
    Help: 980
    Rate: 670
    See the AIDA64 hardware tab. Look at the PCI devices there (they should have USB controllers in them)
  • #12 18780874
    Sylwan1014
    HP EliteBook 8460p USB 3.0 Ports Not Communicating: Installed Drivers, Checked BIOS, Windows 7 For me it looked like this, but in a Toshiba laptop with a bios version 1.30. I only needed to switch from enabled to disabled.
The discussion revolves around an HP EliteBook 8460p experiencing issues with its USB 3.0 ports, which are not communicating with connected devices despite supplying power. The user has installed the necessary drivers, checked BIOS settings, and attempted various troubleshooting steps, including reinstalling the Renesas USB 3.0 Host controller driver. Responses suggest potential causes such as motherboard failure, BIOS settings, or driver issues. Recommendations include testing USB functionality with a bootable Linux USB, checking for chipset drivers, and ensuring USB controllers are enabled in BIOS. Users also mention using diagnostic tools like USB Device Tree Viewer and AIDA64 to identify driver status and hardware configuration.
