Windows 10 USB Ports Not Working - xHCI Compliant Host Controller Issue, Latest Drivers, BIOS
kapelooo 8637 8
  • #1 16479915
    kapelooo
    Hello, after installing the new original win 10 system, my usb ports are not working. Everything else works fine. The mouse lights up, but it doesn't work. The bios usb is on. All updates are. The only fault is with the xHCI USB compatible host controller. There is an exclamation mark like this in the device manager. When updating drivers it is written that they are the latest. Uninstalling nothing gives me the same appearance. I installed all the drivers from the manufacturer's website. Thanks in advance for your help.
  • #3 16479984
    kapelooo
    Downloading new drivers does not give anything, all programs, etc., show the current driver from 07/15/2017
  • #4 16479994
    sosarek
    Help: 9320
    Rate: 15541
    Enter Safe Mode, remove all USB controllers from it, restart, wait for the system to reinstall them.
    Z
    Pka, Poznań, 60-850
  • #5 16480018
    kapelooo
    It installed with an error
  • #6 16480035
    sosarek
    Help: 9320
    Rate: 15541
    Chipset Drivers Installed?
    What does it mean, everything that was on the page?
    Z
    Pka, Poznań, 60-850
  • #9 16481659
    kapelooo
    I installed drivers for my motherboard from the msi site, still nothing. It doesn't work in safe mode either. Only works in the bios. Windows 10 USB Ports Not Working - xHCI Compliant Host Controller Issue, Latest Drivers, BIOS
After installing Windows 10, the user experienced non-functional USB ports, with the xHCI Compliant Host Controller showing an error in Device Manager. Despite confirming that BIOS USB settings are enabled and all updates are installed, the issue persists. Suggestions include entering Safe Mode to remove and reinstall USB controllers, ensuring chipset drivers from the manufacturer's website are installed, and checking USB functionality in Safe Mode. The user confirmed that the USB ports do not work in Safe Mode and have only functioned in BIOS, despite installing drivers from the MSI website.
