Title: Reinstalling Windows System - Encountering No Drivers Issue with USB Ports (Windows 7 & 10)
apoleq 7215 17
How can I get Windows 7 or 10 to install from a USB stick when the installer stops at partition selection and says no drivers are available?
Try installing in Legacy mode, use a USB 2.0 port, and recreate the installation media if needed, because the problem can be caused by UEFI/boot settings or a bad boot image [#17253927][#17253948][#17253977] In BIOS, check the storage mode as well: switching AHCI to ATA/IDE and disabling UEFI-related options was suggested as a fix for similar “missing drivers” installation screens [#17266261] If the board has multiple SATA controllers, the installer may also need the correct storage driver for the controller actually connected to the system disk [#17266261]
  • #1 17253904
    apoleq
    Hi, at the beginning, sorry, similar topics have already been discussed, but I have not found a solution in any of them, maybe because of the lack of it, maybe because of the lack of knowledge to understand the nature of the problem.
    please be understanding :)
    I decided to reinstall the system as strange things are happening to me related to the Internet (as the only device in the house, the download barely flies 1Mb / s with a 250Mb / s connection, good range, 100% upload, nothing is visible in the manager, replacing the network card nothing she did not give ...) and during the installation the stairs began, I note that I have done it dozens of times, but I have never encountered a lack of drivers.
    Regardless of which port I connect the USB from windows (I tried with 7 and now with 10), I get a message about the lack of drivers,
    as I wrote above, it installs from usb in UEFI mode (or whatever it is called; p), I prepared the flash drive first in UltraISO, then in RUfus 3.0
    The place where it calls for drivers is the moment of selecting the partition, I can't do anything there, neither load the drivers nor format the system disk
    Ladies and gentlemen, please give me tips on how to jump over it? Help me
    I will add that the computer is a pc, ASUS motherboard, maybe something in the BIOS needs to be changed?
    • Title: Reinstalling Windows System - Encountering No Drivers Issue with USB Ports (Windows 7 & 10) windows.jpg (132.43 KB) You must be logged in to download this attachment.
  • #2 17253927
    qs300
    Help: 242
    Rate: 362
    Have you tried installing in Legacy mode?
  • #3 17253947
    Pedros050
    Help: 2471
    Rate: 3927
    To which USB port have you plugged the pen to 2.0 or to the 3.0 port?
  • #4 17253948
    qs300
    Help: 242
    Rate: 362
    If to USB 3.0 port, it can request drivers, plug pendrive in USB 2.0 port, it can help.
  • #5 17253969
    apoleq
    Sorry, I forgot to write. I plug Pena into port 2.0, I tried, following the instructions from the Internet, after the message about the lack of drivers, unplug it and plug it into another port, with no effect.
    If Legacy is the latter mode when selecting boot (not UEFI) then I tried, same message in the same place.
    I have installed Windows many times on this computer, never had any problems
  • #6 17253977
    qs300
    Help: 242
    Rate: 362
    It is also an option that the system image was badly recorded on the pendrive. If you have anything, record the image again and try reinstalling the system.
  • #7 17253988
    apoleq
    I've already uploaded the image 5 times, different ISO files, both Windows 7 and Windows 10, using UltraISO and using Rufus 3.0, the same each time.
  • #8 17253989
    Pedros050
    Help: 2471
    Rate: 3927
    And the second option is that the ISO image of the system was downloaded with errors.
  • #9 17254052
    krzychupar
    Help: 1490
    Rate: 633
    There are no exclamation marks in the device manager?
  • #10 17254091
    Pedros050
    Help: 2471
    Rate: 3927
    @apoleq Post photos from the BIOS, we will see if you have changed something there and you have a problem installing the system?
  • #11 17266183
    apoleq
    I attach screenshots from the bios and the error screen
    Title: Reinstalling Windows System - Encountering No Drivers Issue with USB Ports (Windows 7 & 10) Title: Reinstalling Windows System - Encountering No Drivers Issue with USB Ports (Windows 7 & 10) Title: Reinstalling Windows System - Encountering No Drivers Issue with USB Ports (Windows 7 & 10) Title: Reinstalling Windows System - Encountering No Drivers Issue with USB Ports (Windows 7 & 10)
    I tried in the advanced> sata section to change to legacy, but then after rebooting, I get a blue error screen
    there are no exclamation points.
    Is it possible that the motherboard got damaged somehow?
    Recently, the network card connected via the pci socket started to work incorrectly, replacing the network card did not help, only connecting a new - external via usb did the trick
  • #12 17266190
    Pedros050
    Help: 2471
    Rate: 3927
    In the BIOS you have not set the BOOT pen KING in the first position, only the WD disk. And you need to have a running ISO image on it.
  • #13 17266219
    apoleq
    This is a clear piter, of course I have an ISO image on my USB flash drive, the installation is good because I installed it on another computer and there was no problem, so the flash drive also works.
    Boot in biose, after each shutdown, it automatically sets to WD, hence the screen does not show that, of course, it boots from a pendrive every time
  • #14 17266252
    Pedros050
    Help: 2471
    Rate: 3927
    To make it clear, do you want to install win 10 or win 7?
  • #15 17266261
    g107r
    Help: 811
    Rate: 993
    You can't because? Can't see these files? Did you extract them to .inf files?
    You can have two SATA controllers, like I do on the MSI board, in addition there is one based on a Marvell chip that supports 1 SATA port of a different color, also it resulted in not detecting the drive plugged in without giving drivers. Is there something in this taste ...
    What is the ASUSA motherboard?
    On the laptop it helped me - I think - switching AHCI mode to ATA, IDE mode ?? in addition to disabling these UEFI related options.
    Let's say a pen recorded with a program that worked without any problems with non-UEFI discs, no longer started on a UEFI laptop.
    Rufus helped, but also, and it only happened after this AHCI was changed, or so I think. Do you have such an option in this bios?
    They made a mess with these new bios.
    From the last picture, it looks like a seven.
  • #16 17266284
    Pedros050
    Help: 2471
    Rate: 3927
    It is possible that a friend put Pena in the USB 3.0 port. And not in USB 2.0, of course, how does it have?
  • #17 17266356
    ak6
    Help: 156
    Rate: 139
    apoleq wrote:
    I connect Pena to port 2.0
  • #18 17266368
    Pedros050
    Help: 2471
    Rate: 3927
    @ ak6 We don't even know the specifications of the computer so we can't be sure if it was really port 2.0? Why is I asking for the correct driver?
The discussion revolves around a user experiencing driver issues while reinstalling Windows 7 and 10, specifically related to USB ports. The user reports that despite multiple attempts to install the operating system using a USB flash drive prepared with UltraISO and Rufus 3.0, they encounter a "lack of drivers" message. Suggestions from other participants include trying different USB ports (noting that USB 3.0 may require additional drivers), switching to Legacy mode in BIOS, and ensuring the correct boot order is set for the USB drive. The user confirms they have used USB 2.0 ports and have re-recorded the ISO multiple times. There are concerns about potential motherboard damage, especially since a previously functioning network card has also started malfunctioning. Participants recommend checking BIOS settings and the integrity of the ISO image.
TL;DR: Seeing “missing drivers” mid‑install? After 5 reimages, "I’ve already uploaded the image 5 times" points to USB/BIOS, not ISO. Fix by using USB 2.0, recreating media with MCT/Rufus, and checking storage/boot settings. [Elektroda, apoleq, post #17253988]
Why it matters: This is for Windows 7/10 installers who hit the “missing driver” prompt at disk selection on ASUS/UEFI systems and want a fast, reliable fix.
  • Windows 7 has 0 native USB 3.0 drivers; use USB 2.0 or inject USB 3.x drivers into the image. [“Intel Windows 7 USB 3.0 Creator Utility”]
  • Windows 10 USB installers need a blank 8 GB+ flash drive when created with the Media Creation Tool. [“Download Windows 10”]
  • Changing SATA mode after Windows is installed can trigger INACCESSIBLE_BOOT_DEVICE (0x7B) BSOD. [“INACCESSIBLE_BOOT_DEVICE”]
  • A secondary SATA controller (e.g., Marvell) can hide drives until you load its driver. [Elektroda, g107r, post #17266261]
  • Windows 7 support ended Jan 14, 2020; prefer a clean Windows 10 install on modern hardware. [“Windows 7 support has ended”]
How do I quickly fix the “missing media driver” error during Windows setup?
Try this: 1) Move the installer to a rear USB 2.0 port on the motherboard. 2) Recreate the USB using Microsoft’s Media Creation Tool or the latest Rufus, then retry. 3) If it persists, switch to a different USB stick and port; avoid hubs and front-panel ports. This resolves most “missing driver” prompts caused by flaky ports or media. [Rufus FAQ]
Should I install from a USB 2.0 port instead of USB 3.0?
Yes. USB 3.0 ports can trigger the driver prompt during setup, especially with Windows 7. Use a native USB 2.0 port on the rear I/O. As one expert noted, “If to USB 3.0 port, it can request drivers.” This simple swap often clears the issue immediately. [Elektroda, qs300, post #17253948]
Legacy BIOS or UEFI—what’s best for this install?
Use UEFI with GPT for modern Windows 10 installs. Use Legacy BIOS with MBR for older systems or specific compatibility needs. Match your USB creation settings (GPT/UEFI or MBR/BIOS) to the firmware boot mode you select. Mixing modes can block disk selection or installation. [“MBR or GPT partition style”]
My ISO/USB works on another PC. What should I check on this ASUS board?
Confirm the BIOS keeps the USB first in the boot order. Some systems revert to the HDD after restarts, which interrupts setup. Re-enter the boot menu and pick the USB each time, if needed. Then try a rear USB 2.0 port and rerun setup. [Elektroda, apoleq, post #17266219]
Why can’t Windows Setup see my disk at the partition screen?
You may be on a secondary SATA controller that needs drivers, or the SATA mode doesn’t match. Try moving the drive to the primary chipset ports, then retry. Or click Load driver and supply the controller driver. “You can have two SATA controllers,” which explains missing disks. [Elektroda, g107r, post #17266261]
Changing SATA/AHCI mode caused a blue screen—what happened?
Switching AHCI/IDE/RAID after Windows is installed breaks the boot storage path and throws INACCESSIBLE_BOOT_DEVICE (0x7B). Set the desired mode before installation, or change it later only with the correct driver preparation steps. Otherwise, Windows cannot access the boot device. [“INACCESSIBLE_BOOT_DEVICE”]
How do I load storage or USB drivers during setup?
In Windows Setup, choose Load driver. Point to the folder holding .inf files on your USB stick. For Intel RAID/AHCI, use the Intel RST “F6” driver package matching your version and CPU platform. Use x64 drivers for 64-bit Windows images. Then your disk should appear. [“Intel RST F6 Driver”]
Could a corrupted ISO be the reason for the “missing drivers” prompt?
Yes. A bad ISO or a poorly written USB can trigger that prompt. Recreate the media from a clean image and write it again to the USB drive before retrying the install. This eliminates many intermittent media errors at setup. [Elektroda, qs300, post #17253977]
Which tool should I use to create the installer—Rufus, UltraISO, or Microsoft Media Creation Tool?
For Windows 10, use the Microsoft Media Creation Tool. It downloads the correct files and builds a bootable USB. You need at least an 8 GB flash drive. Rufus is excellent when you must control GPT/MBR or partition scheme options. [“Download Windows 10”]
How do I choose GPT or MBR in Rufus for this board?
Select GPT if you will boot in UEFI mode. Select MBR if you will boot in Legacy/CSM mode. Ensure the firmware’s boot selection matches your USB’s partition scheme. Mismatches cause installation blocks or missing disks. [“MBR or GPT partition style”]
Are front‑panel USB ports okay for installs?
Prefer rear motherboard USB ports. They connect directly to the chipset and are more stable during setup. Avoid hubs and front-panel ports when you see “missing driver” errors. Using a different rear port often fixes the issue instantly. [Rufus FAQ]
Can Windows 7 install on a PC with only USB 3.x ports?
Yes, but you must inject USB 3.x drivers into the Windows 7 image first. Use the Intel Windows 7 USB 3.0 Creator Utility or similar slipstream methods. Without those drivers, keyboard, mouse, or installer media may not work. [“Intel Windows 7 USB 3.0 Creator Utility”]
Should I check Device Manager before wiping the system?
Yes. Look for exclamation marks to spot existing driver issues that may inform your install plan. It can reveal failing devices or missing drivers before you start. Capture screenshots to compare after the reinstall. [Elektroda, krzychupar, post #17254052]
