Seeking Recommendations: Linux-Based ENIGMA2 Satellite Tuner to Replace OPTICUM 9500 HD
marcelino 7935 9
Which Linux-based ENIGMA2 satellite tuner should I buy to replace an OPTICUM 9500 HD that hangs and slows down with addons?
For a Linux/ENIGMA2 replacement, the thread points to the VU+ Solo 4K UHD as the safest choice, with the Vu+ Ultimo 4K as the richer option if you want to spend more [#16609798][#16955792] The original poster set a budget of up to PLN 1500 and wanted Wi‑Fi, 4K, hard drive support, a strong CPU/RAM, and ENIGMA2 with the latest plugins, skins, streaming, 3D movies, and web features [#16603407][#16603547] Based on that, the poster leaned toward the VU+ Solo 4K UHD Triple Tuner PVR and asked whether a 2-core or 4-core processor was worth paying extra for [#16608368] One reply also mentioned Dreambox 900, but the more consistent recommendation in the thread was VU+ Solo 4K or, for a higher-end model, Ultimo 4K [#16603017][#16609798]
  • #1 16601811
    marcelino
    I currently have an OPTICUM 9500 HD tuner. Unfortunately, it often hangs and when you try to load more addons, its work efficiency drops to 0. The tuner works on the ENIGMA2 software.
    I am looking to buy a tuner also based on Linux and ENIGMA2 software. With the difference that the above-mentioned problems did not occur, and moreover, to make better use of it. Future purchase. I am asking for information in this topic. What tuner would you buy for yourself?
  • #2 16603017
    macieja
    Help: 78
    Rate: 266
    Hello, I would recommend this DREAMBOX 900
  • #3 16603299
    simhak
    Help: 109
    Rate: 336
    Provide a budget, the price range of this type of equipment is huge.
  • #4 16603407
    marcelino
    Max up to PLN 1500 gross. Unless the functionality of the equipment will be worth more than 200-300 PLN. The equipment is to be good, to fulfill its task. I do not need miracles, i.e. additional color displays on the tuner that I will not use.
    Budget budget but the question is what equipment to buy to be satisfied. It's about to walk everything ;-) No exaggeration. If there is a tuner that can handle everything for 1000 PLN, it will be ok. I am asking for examples of solutions.
  • #5 16603521
    simhak
    Help: 109
    Rate: 336
    So write what you expect, what is "going to walk"?
  • #6 16603547
    marcelino
    WiFi, 4K, Hard drive, Powerful processor + RAM memory
    He has to walk on it:
    - ENIGMA2, the latest plugins, skins, streaming, 3D movies, www,
    What will you say about the tuner: VU + SOLO 4K UHD TRIPLE TUNER PVR ???
  • #7 16608368
    marcelino
    I think I have already chosen the tuner! VU + SOLO 4K UHD TRIPLE TUNER PVR
    My last question is a 2 or 4 (four-core) processor in the tuner? How to invest? Is there a need to overpay?
    This?
    1. http://allegro.pl/vu-ultimo-4k-uhd-enigma2-oscam-distributor-hemm-i6679045306.html
    whether this:
    2. http://allegro.pl/vu-solo-4k-uhd-twin-oscam-od-distributor-hemm-i6564042623.html
    Pozdr.
  • #8 16609798
    Fotodetektor
    Level 30  
    Help: 101
    Rate: 335
    Solo4K or quite rich Ultimo4K
    OMNI-SAT
    WP 11, Wołów, 56-100 | Company Website: www.omnisat.pl
  • #9 16955792
    flips1
    I have vu solo4k ? very happy to recommend
  • #10 16984444
    lisek
    Service technician RTV
    Help: 6347
    Rate: 6876
    Offer in the UK for 4k tuners (for interesting ones, for example priced), from the bottom shelf price link
    Vu + Solo 4K Ultra High Definition Twin PVR Linux Tuner
    RRP: ? 399.95 (* was)
    Your Price: ? 348.95
    (You save ? 51.00)
    e.g. (alza.co.uk) is already ? 293.90
    ps
    Forum about (Vu + solo) link
The discussion revolves around finding a reliable Linux-based ENIGMA2 satellite tuner to replace the OPTICUM 9500 HD, which has performance issues such as hanging and inefficiency with addons. Users recommend various models, with a focus on budget considerations (up to PLN 1500). Key features desired include WiFi capability, 4K support, a powerful processor, and compatibility with the latest ENIGMA2 plugins and streaming services. The VU+ SOLO 4K UHD TRIPLE TUNER PVR is highlighted as a strong candidate, with discussions on whether to opt for a dual or quad-core processor. Other models mentioned include the DREAMBOX 900 and VU+ Ultimo 4K.
