Disable WiFi on Netia Spot Router: Button or Computer Settings for Wired Internet Usage
cinekkk1 6126 7
  • #1 16601853
    cinekkk1
    Is it possible to use the Internet from Netia at all without WiFi enabled? I have Modem and Netia Spot with Netia, and the WiFi signal is still on, and I do not use it at all. Can it be turned off with a button on the router or do you need to change any settings in the computer?
    mariuszp19
    Help: 310
    Rate: 409
    Page 15 of the manual.
    • Netia_Spot_bezprzewodowe_serce_Twojego_domu.pdf (2.86 MB) You must be logged in to download this attachment.
  • #3 16601926
    cinekkk1
    Well done, it worked. Thanks a lot. A neighbor who has a small child asked me to do this and she wanted to limit these (if I'm not mistaken) WiFi radio waves sent by the router. I do not want to dwell on this topic, because what a person is a different opinion and point of view, but I have a question, is it now turned off, the router does not actually send a radio signal anymore and you can sleep peacefully or maybe there is something responsible for WiFi inside there still can radiate?
    mariuszp19
    Help: 310
    Rate: 409
    The signal is turned off.
  • #5 16746963
    kuzwajegomac333
    I was looking at the manual and there is no way to turn it off and I need it because my mother has cancer and cannot have radiation
  • #6 17198638
    majka420
    Rate: 27
    Is this really true with the harmfulness of wifi waves?
    I am asking because I have a family member in remission.
  • #7 17198691
    makosuu
    Help: 369
    Rate: 370
    Nobody knows that. So far, there is no concrete evidence of either harmfulness or harmlessness. But every day we are in electrosmog and we live on. Switching off one 100mw source is a drop in the ocean, a placebo effect.
  • #8 17218173
    majka420
    Rate: 27
    Ok, I already have a net connected ;) Subject to be closed
The discussion revolves around disabling the WiFi feature on the Netia Spot router to use wired internet exclusively. Users inquire about the possibility of turning off the WiFi signal either via a physical button on the router or through computer settings. A user confirms that the WiFi signal can be turned off, referencing the router's manual. Concerns about the potential harmful effects of WiFi radiation are raised, particularly for individuals with health issues. However, the consensus suggests that while the WiFi can be disabled, the overall impact of such actions on health remains uncertain.
