Multiroom Cyfrowy Polsat: Troubleshooting Issues with Additional Decoder & Satellite Dish Signal
Maratt 25725 11
How do I connect two Cyfrowy Polsat Multi Room decoders so both get satellite signal when one cable is currently split with a tee?
Each decoder/tuner needs its own satellite feed, so a tee splitter will not work; run a separate cable from the dish to each decoder or use a twin/quad converter (LNB) for two inputs [#16949747] [#16949738] [#16950054] In practice, pulling an extra cable directly from the dish without any tees fixed the problem [#16956500] If you are using Multiroom HD, each additional decoder also needs its own activation with the card from the basic decoder [#16949738]
  • Need separate cable from dish to each decoder
    #1 16949660
    Maratt
    Cyfrowy Polsat Multi Room today I've chosen one additional decoder for my home and when I connect it on one decoder there is a picture and on the other there is .. when I disconnect the cable from this decoder which works on the other starts working ... not how to solve the problem>? I will add that the two cables are on a kind of a tee, i.e. one cable transmits a satellite signal to two cables, the solution will be carrying an additional cable directly from the satellite dish?
    Periodic activation required for each additional decoder
    #2 16949738
    Pedros050
    Help: 2471
    Rate: 3930
    Hello. Each decoder must be connected to the antenna installation. You can connect more than one decoder to one antenna using a "twin" or "quad" converter or connect decoders to separate satellite dishes.
    Periodic activation of the Service
    Additional decoders with the Multiroom HD service require periodic activation with a card from the basic decoder. To activate, you must:
    a. remove the card from the basic decoder,
    b. remove the card from the additional decoder,
    c. insert the card from the basic decoder into the additional decoder and wait for the additional decoder to confirm unlocking the signal
    d. Insert the appropriate card into the additional decoder and the basic decoder.
    Each additional decoder requires individual activation.
    Separate satellite cable needed for each tuner
    #3 16949747
    Antenak
    Help: 12
    Rate: 24
    Exactly. For each tuner a separate cable from the antenna, no tee
  • Separate satellite cable needed for each tuner
    #4 16949774
    Maratt
    Okay, then I'll buy an extra aerial cable tomorrow and see how it will be; P ;)
  • #5 16949775
    Pedros050
    Help: 2471
    Rate: 3930
    And what kind of converter does he have?
    Antenak
    Help: 12
    Rate: 24
    Just what converter because you need a Twin converter for two inputs
  • #7 16950083
  • #8 16950138
    Antenak
    Help: 12
    Rate: 24
    It depends on what decoders the author has. Do they support unicable
  • #9 16950317
    Antenak
    Help: 12
    Rate: 24
    It seemed to me that only evo supports unicable
  • #11 16952575
  • #12 16956500
    Maratt
    I did not say a few days because the computer fell to me, but I bought an additional cable and led it directly to the antenna without any tees etc. and it works, the problem disappeared, also if someone will have it as I will work on one decoder and on the other it will not work connected tee is directly pull the cable from the plate ;) thanks for the help. Antenak.
The discussion revolves around troubleshooting issues with a Cyfrowy Polsat Multiroom setup, specifically regarding the connection of an additional decoder. The main problem is that when one decoder is connected, the other does not receive a signal. Solutions proposed include ensuring each decoder has a separate cable directly from the satellite dish rather than using a tee connection. Users recommend using a twin or quad converter for multiple decoders and highlight the need for periodic activation of additional decoders with the main decoder's card. The author confirmed that after running a new cable directly from the antenna, the issue was resolved.
TL;DR: Don’t split one coax with a tee; fix by separate feeds or SCR/Unicable. Budget ~130 PLN, and “In decoders, you start Unicable 1 and Unicable 2.” [Elektroda, 1098678, post #16950083]
Why it matters: This FAQ helps Cyfrowy Polsat Multiroom users quickly fix no-signal or either‑decoder‑works issues without guesswork.
Why does one decoder show a picture and the other goes blank when both are connected?
You’re splitting one satellite feed with a tee. The decoders fight for voltage/band switching, so only one locks signal. Run separate coax from the LNB for each tuner or use an SCR/Unicable setup. The OP saw exactly this symptom when using a tee. [Elektroda, Maratt, post #16949660]
Can I use a simple TV ‘tee’ or passive splitter on a satellite cable?
No. Satellite decoders control the LNB with 13/18 V and 22 kHz. A tee lets commands collide, causing loss of picture. Use one dedicated coax per tuner, or adopt SCR/Unicable with proper splitters. “For each tuner a separate cable from the antenna, no tee.” [Elektroda, Antenak, post #16949747]
What LNB do I need to connect two Cyfrowy Polsat decoders from one dish?
Use a Twin LNB and run two separate coax lines, one to each decoder. For three or four decoders, use a Quad LNB. This avoids band/polarity conflicts and keeps both receivers stable. “You need a Twin converter for two inputs.” [Elektroda, Antenak, post #16950054]
Is there a way to run multiple decoders over one cable?
Yes—use an SCR/Unicable LNB plus rated splitters. Enable Unicable in each decoder’s menu. The suggested setup used splitters up to ~2040 MHz with power pass, with a typical hardware cost around 130 PLN. “Start Unicable 1 and Unicable 2.” [Elektroda, 1098678, post #16950083]
Do all Cyfrowy Polsat decoders support Unicable (SCR)?
No. Some models may lack Unicable support. One participant noted that only the Evo model supported Unicable in their experience. Verify your exact decoder model before buying SCR gear. This is a common edge case that breaks shared-cable plans. [Elektroda, Antenak, post #16951758]
How do I activate an additional Multiroom HD decoder?
Follow this 3‑step card procedure: 1. Remove cards from both decoders. 2. Insert the main decoder’s card into the additional decoder and wait for unlock. 3. Return each card to its correct decoder. Repeat for each extra decoder as needed. [Elektroda, Pedros050, post #16949738]
Will adding a second direct cable actually fix the issue?
Yes. The thread author replaced the tee with a new direct run from the dish and the problem disappeared. Separate feeds eliminate voltage and band conflicts and stabilize both receivers. This is the simplest and most reliable remedy reported. [Elektroda, Maratt, post #16956500]
Can I keep one dish and still connect multiple decoders?
Yes. Either use a Twin/Quad LNB with dedicated cables, or keep one cable and switch to an SCR/Unicable LNB with proper splitters. Using separate dishes is also possible but rarely necessary when the correct LNB is installed. [Elektroda, Pedros050, post #16949738]
What splitters should I buy for an SCR/Unicable installation?
Choose satellite splitters rated to about 2040 MHz and with DC power pass. They allow the LNB to receive control voltage and tones. Pair them with an SCR/Unicable LNB, then enable Unicable in your decoder menus. [Elektroda, 1098678, post #16950083]
I still lose signal after wiring correctly—what should I check?
Confirm each decoder has its own LNB output, connectors are crimped cleanly, and no tee remains inline. If sharing one cable, verify Unicable mode and the correct user band settings per decoder. Replace any non‑rated splitter. [Elektroda, Antenak, post #16949747]
Do I ever need a second dish instead of a new LNB?
You can use separate dishes to isolate feeds, but it’s usually simpler to fit a Twin/Quad LNB on one dish. That supports multiple decoders without alignment headaches or extra mounts. It’s a supported approach for Multiroom. [Elektroda, Pedros050, post #16949738]
What’s the fastest low-cost fix if I’m not changing hardware?
Run a second coax directly from the dish’s LNB to the additional decoder, bypassing any tee. This mirrors the OP’s successful fix and costs only the cable and connectors. It restores full, independent control to both decoders. [Elektroda, Maratt, post #16956500]
Why do decoders need independent cables in non‑SCR setups?
Each decoder commands the LNB’s band and polarization. Sharing one line causes conflicts, so only one decoder tunes correctly at a time. Dedicated cables prevent these clashes and keep both receivers stable. [Elektroda, Antenak, post #16949747]
What menu settings should I change when migrating to Unicable?
Enable Unicable (SCR) in each decoder and assign different Unicable user bands. The thread guidance mentions using Unicable 1 and Unicable 2 for two devices. Match your splitter and LNB to SCR specs. [Elektroda, 1098678, post #16950083]
How can I tell if my problem is the tee splitter?
If one decoder only works when the other is unplugged, the tee is the culprit. This behavior points to control signal conflicts on a shared line. Replace the tee with either a second cable or an SCR solution. [Elektroda, Maratt, post #16949660]
