Krups EA8005 Espresso Machine: Undocumented Error with Flashing LEDs, Coffee Plunger Issues
heretyk 14358 9
Why does a Krups EA8005 show an undocumented flashing-LED error and leave the brew piston stuck down when trying to make coffee?
It is probably a general functional anomaly, not a special cleaning mode, and the best lead is an intermittent electrical fault in the machine’s wiring, connectors, microswitches, or PCB that appears when the brew piston moves under load [#16628136][#16603379][#20659440] One reply notes that the manual only describes this as “continuously flashing light: functional anomalies” [#16628136] Another suggests checking all electrical connections, cables, and contacts around the boiler because a bad contact or short may happen at the moment of highest stress [#16603379] A later reply says Krups EA8005 failures are often on the PCB and that the microswitches may not be the real cause [#20659440] It does not sound like the normal cleaning program, because that would typically make only the clean LED blink and the rinse button should respond [#16602508][#16602542]
  • #1 16602498
    heretyk
    Rate: 11
    Good morning,
    I have an express Krups EA 8005. The error is that after starting and heating, when trying to make coffee, the machine displays an error like in the video attached to the post.
    The combination of flashing LEDs indicating the error is not described anywhere or I have found all other combinations :) The coffee machine itself seems fine after opening, I didn't notice any leaks. It is characteristic that the problem occurs when the plunger goes down and it remains there, which prevents the removal of the tray for removing coffee residues. Only lifting the piston up mechanically helps. Does anyone have a clue where the problem may be?
    • 20170708_115047.mp4 (1.34 MB) You must be logged in to download this attachment.
  • #3 16602542
    heretyk
    Rate: 11
    Then only the "clean" LED should blink. Anyway, pressing the rinse button does nothing.
  • #5 16603310
    heretyk
    Rate: 11
    I probably didn't make myself clear, but this coffee cup cannot be pulled out because it is blocked by a plunger.
    An attempt to cheat, i.e. to carry out this operation in the given sequence with the espresso machine open and manipulation of the microswitch, only resulted in both lamps blinking simultaneously.
    It only helps to raise the piston. Then the machine seems ready to work, but after pressing the coffee button, the situation repeats itself. The coffee machine starts working normally, the piston goes down and again the error ...
  • #7 16603353
    heretyk
    Rate: 11
    nioop wrote:
    And in the error window what number is displayed? Probably 5 or 7?
    If we are talking about this window under the metal grill / service cover, where the water hardness is displayed, unfortunately nothing is displayed.
    In addition, I have to admit a mistake, it is EA8005, not EA8010, only now I looked at the nameplate and corrected the previous post.
  • #8 16603379
    nioop
    Home appliances specialist
    Help: 503
    Rate: 3337
    Therefore, I would suggest looking at all electrical connections, cables, etc.
    It looks as if at the moment of the greatest stress, pressure on the boiler, there was some short circuit or inaccurate contact of electrical connections.
    Kawa i Naprawa - Serwis AGD
  • #9 16628136
    Władek1953
    Hello. I will join this mat because I have the same problem with the blinking LED from the reservoir. Model 8005.0 leaks. All seals replaced. The micro switches (there are 3) checked and after a few times 1 coffee starts blinking and sneezes. What's the problem?
    Added after 47 [minutes]:
    In the manual I found "Continuously flashing light: functional anomalies" What could this mean?
  • PC board failure blamed for Krups faults
    #10 20659440
    podgor600
    Samo novi aparat, na žalost, Krups je napravio aparat sa par mikroprekidača koji nemaju nikakvu korist i koji poslednji izgore. PC board je problem.
    Kod Krupsa je nakon 1 godine korišćenja sve problem.
    Kod Krupsa je nakon 1 godine korišćenja sve problem. Pozdrav iz Crne Gore.
✨ The discussion revolves around issues with the Krups EA8005 espresso machine, specifically an undocumented error indicated by flashing LEDs during the coffee-making process. Users report that the plunger becomes stuck, preventing the removal of the coffee residue tray. Attempts to resolve the issue include checking for leaks, manipulating microswitches, and inspecting electrical connections. One user mentions that the machine displays "Continuously flashing light: functional anomalies" in the manual, suggesting potential electrical faults. Another user notes that the machine's design includes micro switches that may fail, indicating a possible problem with the PC board after a year of use.
