Krups EA8050 Error 01 - Troubleshooting Display Error & Strange Noises in Coffee Machine
butek22 11262 7
  • #1 16542318
    butek22
    Please help me error 01 displaying in the krups ea8050 machine. What he is associated with does not make coffee very strange noise
  • #2 16544584
    MARCIN.SLASK
    Home appliances specialist
    Help: 1037
    Rate: 2655
    This is a distributor positioning error.
    I used to have a coffee machine where the distributor drive was damaged and it showed such an error.
  • #3 16545785
    nioop
    Help: 503
    Rate: 3337
    Like a friend above ..
    If it "gushes" it is blocked
    If the engine turns quickly and quietly then the drive is broken.
    If you have not had experience in setting up distributors, I suggest buying and replacing a new one, remembering to replace the seals in the actuator - it falls out with a new distributor.
    Of course, I would like to remind you how fragile the hose fittings of distributors are. Also, please be careful ...
    Kawa i Naprawa - Serwis AGD
  • #4 16547351
    butek22
    It is exactly as you write, the maker rattles loudly as if it was blocked, in which case I will order a new distributor costs PLN 215, and cylinder seals.
    Thank you very much for your help
  • #5 16547477
    MARCIN.SLASK
    Help: 1037
    Rate: 2655
    I definitely mount: MS-5370795 (set with hoses and 4 hose clamps). Maybe not the cheapest, but the whole and probably works for many years.
  • #6 16557395
    butek22
    Ok, the distributor is replaced and a new piston with gaskets is installed, everything works as it should :-)
    Thanks for the help.
    I still have a question, what is the purpose of this spring on the piston is that the spring bends like a pen
  • #8 16557659
    butek22
    Oh, it's good to know, of course, the spring is in place, out of pure curiosity I wanted to know what it is for
✨ The Krups EA8050 coffee machine is displaying Error 01, which is associated with a distributor positioning error. Users have reported that the machine makes strange noises, indicating potential blockage or a broken drive. Recommendations include replacing the distributor and seals, with a specific part number MS-5370795 suggested for purchase. After replacing the distributor and piston, users confirmed that the machine functioned correctly. Additionally, a spring on the piston is noted to scoop coffee residue, preventing grinder failure over time.
