Cyfrowy Polsat TV: Image Jamming on HBO, HD Channels Not Turning On with Double Convoy
KobraKonrad 9885 4
  • #1 16602890
    KobraKonrad
    Rate: 8
    I have Cyfrowy Polsat TV and recently a second television. I bought a double convoy. The signal quality is 70%, and when the HBO is turned on, the picture jams. Some HD channels do not turn on. Earlier, an old concierger with one cable with the same signal quality was not there.
  • #2 16602906
    ntvps
    Rate: 15
    You should start with how large your satellite dish is. It should be 90 cm. so that the image does not get stuck during rain or snow. Please note that there are no obstacles in the form of trees, bushes etc. in the field of view of the antenna at an angle of about 30 degrees.
  • #3 16603022
    andpol 33
    Help: 513
    Rate: 1145
    Badly set antenna, wrong converter set, defective converter.
  • #4 16603303
    simhak
    Help: 109
    Rate: 336
    Which converter?
  • #5 16604623
    ntvps
    Rate: 15
    Write what your Polsat decoder is. In most decoders, to check the level and quality of the signal, press and hold about 10 seconds. a red button that is in line with the yellow, green and blue buttons. Check it out on, for example, TVN (7) and Polonia (108), channel (150) and draw conclusions.
