Opel Astra G radio does not work - Radio connected but not working
Westcik999 8844 2
  • #1 16602926
    Westcik999
    Hello, I am "in the process of replacing the radio", the problem is that the radio is connected correctly (I do not replace the radio for the first time) but it does not work.
    Auto Opel Astra G 2003.
    Radio Manta RS4503.
    The wires are connected properly but the radio is still dead. I checked the fuses that belong to the radio, but they are all in good condition. I have no idea what could be the reason.
  • #2 16602955
    ikar55
    Car audio specialist
    Help: 269
    Rate: 340
    Start by making sure you are connected so that the yellow wire is constantly 12V and the red wire shows 12V when the ignition is turned on.
  • #3 16603781
    Westcik999
    Subject to be closed.
    The problem was a simple wire with voltage was connected to another PIN in the ISO block.
