[Solved] Lenovo C2 K10a40 - Block Contact or User on Child's Phone: Instructions & Forum Search
kasiaszm 15999 6
  • #1 16603455
    kasiaszm
    Rate: 96
    Good morning, I'm trying to block the contact on my child's phone ... I read all the instructions, I searched for Polish and foreign forums and found nothing. Can anyone do it?
  • #2 16603494
    qs300
    Help: 242
    Rate: 362
    If you have this number in the Call Log, press it with your finger and hold it down until the menu unfolds and press "Reject Call". Incoming calls from this number will be automatically rejected.
  • #3 16603500
    kasiaszm
    Rate: 96
    qs300 wrote:
    press it with your finger and hold it until the menu unfolds and press the "Reject call" option
    Unfortunately, I have such a choice:
    - copy to the clipboard
    - edit the number before commencing ..
    qs300
    Help: 242
    Rate: 362
    I already have, I checked on the LG X-CAM: in the call register, click on the phone number, but not on the handset, go to the number edition, at the top next to the Trash icon click on three dots (the menu will pop up) and check the Reject link here.
  • #5 16603671
    kasiaszm
    Rate: 96
    qs300 wrote:
    at the top next to the Basket icon, click on three dots
    There is no basket or menu :(
    I'm trying to create a group of contacts now ... I'm looking for a group setting, maybe it will be there.
    archi3
    Help: 126
    Rate: 101
    If this option is not available, you can quickly install it, for example, via an app. I use "pick up the phone?" And this one has the ability to block all spammers + adding yours. Blocks seamlessly.
  • #7 18252184
    kasiaszm
    Rate: 96
    Solution in the manual.
The discussion revolves around blocking a contact on a Lenovo C2 K10a40 phone. The user seeks guidance after failing to find instructions online. Responses suggest using the call log to reject calls by pressing and holding the number, but the user reports limited options available. Alternative solutions include creating a contact group or using third-party applications like "pick up the phone?" which can block unwanted calls and manage contacts effectively.
