HDMI to VGA Converter: Compatibility with Old Monitor & GTX 1050 Graphics Card
flOw. 8121 10
Can I connect a GTX 1050’s HDMI output to an old monitor with a VGA input using an HDMI-to-VGA converter?
Yes, an HDMI-to-VGA converter should work for connecting a GTX 1050’s HDMI output to an old monitor with a VGA input; the reverse direction, VGA-to-HDMI, will not work [#16607053] The important part is that the converter must be HDMI to VGA, because this is an active conversion, not just a simple adapter [#16607053] If your graphics card has a DVI-I connector, VGA may already be available through that port, so a converter might not be necessary [#16607620] However, simple DVI-I-to-VGA adapters are not guaranteed to work on every card, so compatibility can vary [#16609160]
  • #1 16606749
    flOw.
    Hello, I have a question or such a converter
    will work for me when I connect from this converter HDMI to the graphics card, and VGA to the cable from the old monitor?
    I was looking on the Internet, but all such converters connect the PS3 to the monitor or Image from laptop to the monitor.
    So I repeat the question: Will the converter I sent above work for me with an old monitor with 1 VGA input and a new GTX 1050 graphics card with HDMI input ??
  • #2 16606811
    Heinzek
    Help: 554
    Rate: 494
    flOw. wrote:
    all such converters connect the PS3 to the monitor or Laptop image to the monitor.
    If it works like this, I see no difference why it should not work with a computer.
    ps. You can buy it online and you always have the option of returning without giving a reason within 14 days. (Only the shipping price kills the return's profitability)
  • #3 16606836
  • #4 16606889
    Heinzek
    Help: 554
    Rate: 494
    flOw. wrote:
    HDMI converter to the graphics card and VGA to the cable from the old monitor?
    drobok wrote:
    Heinzek wrote:
    why not work with a computer.
    And if only because it is a reverse conversion
    Will it send a signal from the old monitor to the hdmi in the graphics card?
    Quote from the first better auction:
    The cable allows you to connect a monitor or projector with a VGA connector
    to any device equipped with an HDMI connector, e.g. a smartphone, tablet, laptop, computer, console!
  • #5 16606970
    flOw.
    I don't know anymore. I have a graphics card with dvi, displayport and hdmi inputs and an old monitor with vga input. Will it work if I buy a converter?
    The image probably goes from the graphics card is HDMI to VGA unless I understand it correctly?
  • #7 16607158
    flOw.
    drobok wrote:
    The title clearly says "VGA to HDMI converter" - this will not work.
    The HDMI to VGA converter will work
    I changed, I will give an answer soon (in a few days, because I can't now) whether it actually worked :)
  • #8 16607185
    mariuszp19
    Help: 310
    Rate: 409
    flOw. wrote:
    I have a graphics card from entrances dvi, displayport and hdmi
    With exits, I think.
    Such a converter should work.
  • #9 16607620
    KOCUREK1970
    Help: 3860
    Rate: 5488
    flOw. wrote:
    . I have a graphics card with dvi inputs
    With output - and if it is DVI-I there is no need for converters, the VGA signal is included in this protocol.
    Maybe take a photo of this card's ports and put it here.
  • #10 16607636
    Heinzek
    Help: 554
    Rate: 494
    KOCUREK1970 wrote:
    if it's DVI-I then there is no need to use converters,
    You only need this adapter: HDMI to VGA Converter: Compatibility with Old Monitor & GTX 1050 Graphics Card
  • #11 16609160
The discussion revolves around the compatibility of an HDMI to VGA converter with a GTX 1050 graphics card and an old monitor featuring a VGA input. Users express concerns about whether the converter will function correctly, noting that the direction of signal conversion is crucial. It is clarified that an HDMI to VGA converter is necessary for this setup, as opposed to a VGA to HDMI converter, which would not work in this scenario. Some users mention the potential for issues with certain graphics cards, even those with DVI-I outputs, indicating that compatibility can vary. The conversation highlights the importance of understanding the specifications of both the graphics card and the monitor when selecting a converter.
