[Solved] GTX 1060 does not detect the monitor - Does not detect the monitor
Husaria2 7176 8
  • #1 17242346
    Husaria2
    Hello, I recently bought a new graphics card for my old man, i.e. Geforce 1060 6gb, I have long been used to two monitors and here is the problem. The main one works flawlessly, the second one, but not quite, I read on some forum that I need a signal converter because the card is only for digital and the old monitor has an analog one. So I overzealously purchased two things with alledrog http: // alle ....
    DISPLAY PORT CABLE - HDMI ORIGINAL DISPLAYPORT
    and http: // alle ..
    CONVERTER SIGNAL ADAPTER VGA to HDMI AUDIO FULLHD
    Moderated By RADU23:
    Links to Allegro have been removed. I replaced them with photos and the exact names of the products.
    3.1.18. Do not send links that will cease to be active after some time. This will make the discussion meaningless.
    In the card I only have 1 HDMI input, the rest DP, the main monitor (SAMSUNG S22C300 is already on HDMI, so the second (SAMSUNG SYNCMASTER 2033) from the converter via the adapter was connected to DP, as you can guess, it does not work. So I connected the main monitor via this HDMI adapter> DP and the second through a converter to HDMI and here a shock - none works.
  • #2 17242415
    sylweksylwina
    Help: 1882
    Rate: 2355
    Describe it correctly again. You have in the card outputs not inputs!
    Besides, you bought a signal converter from VGA to HDMI that is, from analog to digital.
  • #3 17242507
    dt1
    Admin of Computers group
    Help: 7315
    Rate: 8292
    You need a DisplayPort to VGA (DSUB) converter. Such for ~ 20 zlotys.
    Connect the second monitor with HDMI-HDMI cable without converters.
  • #4 17242533
    Husaria2
    OKAY. I bought a converter from analog to digital signal because the second monitor - Samsung SyncMaster 2033 (old man) has only a connector VGA . I connected it to the converter
    Spoiler:
    and the converter itself was connected with out in the graphics card with this adapter
    Spoiler:
    Of course, the monitor was not detected, so I decided to check without this DP adapter - I connected the converter to the computer with an HDMI cable and, to my surprise, it also did not work, as it should be.
    When I connected the converter with the HDMI connector, the monitor did not work either, I can buy another converter, but not to turn out, I will spend more on changing the signal for a new monitor. I also made it uphill myself - I could immediately buy what you are talking about, but because I am bathed in hot water, I did not get interested enough in the topic to check if there are any other than VGA> HDMI, but I ordered that one together with an adapter in the hope that it would be raving because, to my peasant reason, it seemed to me that it should.
  • #5 17242539
    dt1
    Help: 7315
    Rate: 8292
    Husaria2 wrote:
    OKAY. I bought a converter from analog to digital because the second monitor - Samsung SyncMaster 2033 (old man) has only a VGA connector. I connected it to the converter
    But you don't want to convert analog to digital, just the other way around. You bought a VGA2HDMI, so you can power the HDMI monitor from the VGA connector on the graphics card. This converter has no right to work, so you should just buy the right one, not the one. There is no need to play with double conversion - first from DP to HDMI, then from HDMI to VGA - one converter from DP to VGA should do the trick.
  • #6 17242540
    sylweksylwina
    Help: 1882
    Rate: 2355
    Husaria2 wrote:
    OKAY. I bought a converter from a signal analog to digital because the second monitor - Samsung SyncMaster 2033 (old man) has only a connector VGA .
    Well this, you should buy a signal converter from digital to analog.
  • #7 17242546
    Husaria2
    Well, that's the way it works, I was convinced the opposite. You pay nothing for stupidity. I will get what you say and let me know about the results. Thanks for the quick replies.
  • #8 17242548
    sylweksylwina
    Help: 1882
    Rate: 2355
    Unfortunately, it doesn't work both ways. It is best to buy a DP to VGA converter as recommended by @ dt1.
  • #9 17261582
    Husaria2
    It took a while, but today I received the converter mentioned by dt1. Everything works as it should, once again many thanks and best regards.
The discussion revolves around a user experiencing issues with their new GeForce GTX 1060 6GB graphics card, specifically regarding the detection of a second monitor, a Samsung SyncMaster 2033. The user initially attempted to connect the monitor using a VGA to HDMI converter, which is unsuitable for their setup as it converts analog to digital signals. Responses from other users clarified that a DisplayPort to VGA converter is needed instead, allowing the digital output from the graphics card to connect to the analog input of the older monitor. After acquiring the correct converter, the user confirmed that the setup worked successfully.
