Daewoo Lanos: Starting Issues After 3-Month Hiatus, Changed Battery & Spark Plugs, Immobilizer
Daimone 4632 16
Why does a Daewoo Lanos crank but not start after 3 months idle, even though the battery, spark plugs, fuel pump and immobilizer seem OK?
The replies point first to a fuel-delivery or injector problem rather than the battery or immobilizer: check whether fuel actually comes out of the line before the fuel filter, and verify injector pulse with a 12V LED or test lamp [#16609387][#16609521][#16609629] If the car has LPG, try starting it on gas by holding the LPG switch during cranking, or separate the gas system from the factory system to narrow the fault [#16609541][#16609626] In the thread, the car eventually started on gas, was driven about 3 km, then switched to petrol and started normally, which suggests the petrol side/injectors likely stuck or needed to be cleared after standing [#16610140][#16610481]
  • #1 16608544
    Daimone
    The car ran without any problems until it was put aside for 3 months without traffic. I replaced the battery and it spins, spark plugs, after turning the key the fuel pump starts up, the light from the immobilizer goes out. After checking the candles, it turned out that they were dry - my friend prompted to put gasoline in the place of the candles, and in fact, as if he would fire, but immediately went out. Any ideas what else I can do myself?
  • #2 16608875
    bubu1769
    Help: 1177
    Rate: 2374
    And emergency firing on gas gives any results?
  • #3 16609347
    Daimone
    I haven't tried because I don't know how to even do it?
  • #4 16609387
    g107r
    Help: 811
    Rate: 993
    Remove the hose in front of the fuel filter, in the bottle, and turn the starter. Add gasoline, because Thunder knows how much and how old you have.
    12V LED diode into the injector plug and see if it flashes while turning.
  • #5 16609391
    bozo86
    Rate: 33
    There you have gas II gen without sequence, so switch to gas and spin ... It will light for sure
    Added after 14 [minutes]:
    In my opinion, injections sie zastaly / zapiekly ... Used occasionally because driving on gas for a 3-month break and stood. Twist and soak in kerosene can move
  • #6 16609430
    g107r
    Help: 811
    Rate: 993
    Such a thing may be over from 1, but what if this hmm, 2 gen is set to 2,000 revolutions?
    Dry candles, first you have to look for where there is gas, if there is any at all. Secondly, do the injectors want to feed it, work?
    After pouring fuel directly, he asked, that is half the success.
  • #7 16609507
    Daimone
    write what, if any, and I can still do to resurrect? is there any filter on the fuel pump? maybe old gasoline clogged the passage
  • #8 16609521
    g107r
    Help: 811
    Rate: 993
    There is a filter, but instead of digging in the tank, see if it flies in front of the filter on the engine bulkhead, and maybe behind.
    It won't fly, then take an interest in what's there.
    In the tank, it is best to change or add fresh gasoline. When they are empty, water vapor condenses on the walls and mixes with gasoline.
    Gasoline from the hose is to fly while turning the starter, not only 1 second after turning on the key.
    How to fire up and whether it is possible to do so will tell the installation instructions, the LPG control unit. You need to know the name, the rest is google.
  • #9 16609537
    Daimone
    Daewoo Lanos: Starting Issues After 3-Month Hiatus, Changed Battery & Spark Plugs, Immobilizer Daewoo Lanos: Starting Issues After 3-Month Hiatus, Changed Battery & Spark Plugs, Immobilizer
    Added after 47 [seconds]:
    I added a photo, so I understand that I have to check all the hoses at the fuel filter
  • #10 16609541
    rafcio_21
    Help: 137
    Rate: 299
    What gas installation do you have, it can fire only from the gas itself. As a rule, before turning on the ignition, you need to press and hold the button in the ignition switch lpg until you turn the starter.
  • #11 16609546
    g107r
    Help: 811
    Rate: 993
    Unfasten one, it will or will not fly from the filter. The one on the left is the exit from the tank.
    You squeeze the white one, you pull the black one. The white clip will stay on the filter.
    What does the fuel gauge show?
  • #12 16609561
    Daimone
    of fuel is a quarter of the tank
  • #13 16609626
    jurekk55
    Level 36  
    Help: 182
    Rate: 1580
    Electrically separate the gas system from the factory system and then start the verification.
    Measurement and verification of the injector installation, power supply and W / N control are usually related to the installation of the gas installation. Timing, error list checked?
  • #14 16609629
    g107r
    Help: 811
    Rate: 993
    It's nice, now check if there is fuel and if the injectors can give it - e.g. this LED, gauge. Whether they serve, then either raise the injectors and see how they spray, or the wet spark plug and the smell of gasoline will be less precise - 3 months it would be possible.
    It was dry here so far.
    The drained fuel can be poured directly into the throttle, in small doses, the bottle cap at a time, with a syringe like you have. When the engine starts to chatter, you only have a problem feeding gasoline into your cylinders. From the pump to the injectors, it is also worth knowing where the petrol is coming.
    On one of the wires of the injector plug there should be a plus with the F14 safety in the cabin, we check it with a light with a bulb.
    You don't have an alarm?
    Immo blocks the injectors, you can also try LPG and go to a mechanic or gas engineer, because gas can also block them, i.e. cut them off.
  • #15 16610140
    Daimone
    thanks very much, I do not have an alarm, but the light from the immobilizer turns off, so it should not block
    Added after 1 [hours] 48 [minutes]:
    thanks to everyone for your commitment and valuable knowledge - I finally fired my lancer on gas, I drove it from 3 km and switched to petrol, it caught it and now it fires without any problems. I wonder what exactly meant that he did not want to get caught and whether there will be any complications in this respect. best regards
  • #16 16610481
    bozo86
    Rate: 33
    There were injections, as I wrote ... Drive a little on gasoline only
  • Check fuel supply, relay, and pump priming
    #17 16610540
    g107r
    Help: 811
    Rate: 993
    We will not find out because you did not check why the candles were dry or whether the fuel was running.
    At a friend's, the injector shut-off relay fell, YOU should have at least two.
    When the fuel pump was replaced, without a basket with sensors, often after replacement there are problems with airing the pump when the fuel level is low - such a good pump, or its sealing, 1/4 of the tank may not be enough then. Sorry, this is more or less checked by lanos owners ...
    3 km of the pump in operation should vent it. You would kill the battery with the starter if it had to "drive" the shaft position sensor for so long, because without the sensor, the pump does not work, except for 1 second from the key. I know because I was taking it out and I had to pour it over because it did not want to pump fuel, and I have no problem with starting it.
    Injections ?, after warming up the engine, they also got hot, and could let the muck go hot. Except that 4 at once? He fired me on two :wink:
    The car had 3 bellows, it's good that it started.
The discussion revolves around starting issues with a Daewoo Lanos after it was inactive for three months. The user replaced the battery and spark plugs, but the engine fails to start despite the fuel pump activating and the immobilizer light turning off. Suggestions include checking fuel flow, inspecting the fuel filter, and ensuring the injectors are functioning. Users recommend adding fresh gasoline, verifying the LPG system, and checking for any clogs or issues with the fuel pump. The user successfully started the car after troubleshooting, indicating that the problem may have been related to fuel delivery or injector functionality.
