Lanos Sedan Troubleshooting: Alternator or Battery Issue After Long Idle Period?
marta443 22074 41
Why does my Lanos sedan fail to start after sitting for a few days or weeks, and is the problem the alternator or the battery?
The battery is the most likely culprit, not the alternator: a healthy charging system should show about 13.9-14.4V at the battery with the engine running, and readings around 14V are generally considered normal [#16794489][#16795075] A 5-year-old battery that was deeply discharged during a 3-week stop can sulphate and lose capacity, so it may start after charging but still collapse after sitting or under load [#16794928][#16794489] Before buying parts, check the battery voltage after a long idle period, do a proper parasitic-draw test, and inspect the battery/alternator/ground connections and clamps for voltage drops or poor contact [#16794066][#16797569][#16798200] One reply also notes that if the battery voltage is already down around 12.3V after rest or drops to about 9.8V before cranking, the battery is effectively bad [#16796931][#16797233] The thread’s later outcome was that fitting a new battery cured the problem [#16800001]
  • #1 16793998
    marta443
    I am the owner of a 19 year old lanos sedan. I have this problem on 10/10/2017:
    I was on vacation for 3 weeks and I returned on 10/10/2017 = the car has not been used, it is not in a garage - it is outside. I didn't take the battery home :( After my vacation I couldn't fire it. I bought jumper cables - fired from someone right away the first time. It came a bit, I drove a bit, I lit it on the same day about 3 times. Unfortunately, I did not charge the battery. I drove about 1 week - no problem. After this week of use, I did not use the car from Thursday to Monday. In the morning he didn't fire up to work. What's worse, it did not fire on the starting cables from another car. I bought a charger, charged it, put it in (around midnight at night) and went to work the next morning (Tuesday) - it fired. When I wanted to come back, he did not fire - but he did fire from someone's car on the starting cable - right away, quickly. The Lord informed me that I have loose clamps. I got home, I improved the clamps, since then it has been working well again for about 1 week. Until yesterday. Yesterday - I drove 14 km to work, the car stood 12 hours. Then I went from work to point B about 25 km. The car stood about 3-4 hours. After that time I got into it and it wouldn't start. Again, a request to fire from someone on the starter cables - no effect, we even tried to charge it for about 5 minutes, even the "support" car did a little gasping. I took the battery home, charged it all night, put it in the car today around 11:00 - it fired without any problems, the first time, quickly.
    The battery I have is: 60 Ah, 540 A , my father says he is "new", so I assume he is 5 years old ;)
    I took the voltmeter readings. Unfortunately, I only have it after firing, because I did not have a voltmeter before firing - make some measurements? Is it enough information that the protector indicated 12.8V when I disconnected it when it finished charging? I don't want to fire it today to get to work tomorrow :P
    Measurements - given in order of reading:
    -After starting the car and driving about 10 km in medium traffic jams - 13.3V
    - after turning on the heating and rear window during gassing, 13.4-13.5V
    - after turning off the heating and rear window during gassing, 13.9 V
    - the car fired, without gassing, without turning anything on inside 13.96 V
    My question - replace the battery? Is the alternator not charging it?
    During the week I travel to work 14 km one way.
    I have been using the car for about a year - the battery has never been discharged, it survived last winter (2016) without any problems.
    Did I damage it with this 3-week break and the fact that I did not charge it but fired it from someone?
    The car has more and more defects and I am thinking of scrapping it. If it is a battery, I will buy a new one, but if I buy a new one and it turns out that it is an alternator, I think that investing in this car makes sense and I will lose a new battery. Such disparities. I would be very grateful for your help :)
    andrzej20001
    Help: 1578
    Rate: 6669
    The alternator is charging poorly
  • #3 16794020
    marta443
    why did it suddenly break down? do the voltmeter measurements again?
    I read something about the cubes in the alternator - does it make sense to replace them?
    andrzej20001
    Help: 1578
    Rate: 6669
    Why does a person get a heart attack? Suddenly and without prior notice. Buy an alternator on the road
    adamkowalski431
    Help: 7
    Rate: 72
    should over 14 have
  • #6 16794043
    marta443
    and what is the cost of installing an alternator? you know how it is, a woman comes to a mechanic ... :)
    andrzej20001
    Help: 1578
    Rate: 6669
    PLN 50 in Lanos
  • #8 16794065
    marta443
    and I will also ask about the battery. Maybe it would also be worn out at the same time? or rather gives advice and will give :)
    enhanced
    Help: 963
    Rate: 883
    First check the voltage on the battery after a long idle time before firing.
    Another is to check the power consumption at a standstill - the meter you have is a matter of connecting in series between the positive battery terminal and the detached positive cable. Enter the ampere value from the meter.
    And he was shooting something at all or immediately all the backlights dimmed when he did not want to fire?
    Because this is the basic thing to check because maybe the battery, not the alternator.
    Of course, the voltage is measured on the battery - almost 14V, I don't know why it should be an alternator? If it is something, check the plus voltage on the alternator, although it looks like a weak battery or other defect.
    Klemy not tarnished? Are they holding well now aren't they loose?
    In general, do the dipped beam headlights / backlight inside / radio dims when firing?
    He was shooting and did not want to smoke or how did he behave?
  • #10 16794159
    nikusert
    Help: 699
    Rate: 1755
    Hello .
    First of all, charge the battery well (about 10h) to full charge. Make sure it does not reach a high temperature, which does not bode long life for it. After full charge, install it in the car and then check the charging. while the engine is running. If it is OK, then you should check if there is a significant power consumption when stationary. The fact that your car suddenly refused to obey you in the morning, there can be many reasons;
    -already a few years old battery
    -small sections of car driving (many receivers turned on, blower, heated windshield, etc.).
    - the aforementioned significant power consumption when stationary by left on the light, radio, door, trunk (of course, when the car is in a garage).
  • #11 16794175
    adamkowalski431
    Help: 7
    Rate: 72
    Get to the electrician
  • #12 16794221
    mczapski
    Level 40  
    Help: 468
    Rate: 1659
    You read about real and imaginary ideas, and nothing will come of it until you have the technical skills. Somehow your description does not show that you grabbed the tools. This is not an objection but an assessment of the situation. And since the parent, apart from issuing an opinion, will also not take any action, it remains to get someone kumaty from the group of males. And in such an old vehicle, of course, everything can refuse to cooperate. But maybe before you act effectively, make things that are kind of obvious. If you are already dragging this battery for charging, do a voltage measurement before charging and it would also be good when you try to start it (during). Almost 14 V with the engine running is not a tragedy yet. It looks to me that there may be faulty connections (e.g. ground cable). But here again the measurements. And the question what does it mean did not fire? Does it spin the starter and how does it spin? Do you hear electromagnet noises etc?
  • #13 16794225
    tadeusz03
    Rate: 14
    It turns out that the voltage regulator is not working properly. It should be over 14V at idle speed with no lights on and heater blower turned on. After turning on the traffic lights and the blower to the max, it should charge no less than 14. The battery, if you write 5 years, may also not hold. Look for the alternator on the road. The cost is not great. If you are charging over 14V and you are still in trouble, you will probably need to look for a battery.
  • #14 16794346
    PREDAT
    Help: 76
    Rate: 141
    But I am almost sure that it works as it should.
    Probably the power consumption at some low level, which after a long standstill
    the battery ended. In addition, falling charging with the receivers turned on
    13.3 - 13.4 the more that winter is coming, it is definitely not enough. Dips on the wires
    alternator-battery (to check, compare the voltage on the battery and alternator)
    Actions:
    -Repair of alternator-battery connections
    -Find a thief (often a badly connected radio, some crappy alarm control unit)
    Who will do it?
    The decision is up to the author :-)
    tzok
    Help: 3176
    Rate: 6549
    As the alternator idles with no load gives a voltage of 14V, it is not so tragic. It should be 14.4V, so as the alternator (or rather the regulator) heats up, the voltage drops is normal and appropriate, but it should not drop below 13.8V. On the other hand, the 5-year-old battery, which in addition was deeply discharged, should rather be replaced.
    However, I do not like this:
    Under what conditions was it 13.3V, and under what 14V?
  • #16 16794707
    marta443
    current consumption after disconnecting the positive clamp on the battery 0.5mA - no current thief. Tomorrow morning I will measure and write what the voltmeter will show me - before and after firing and after reaching the place before and after turning off the engine - these 4 measurements will be enough? tomorrow morning I won't have too much of anyone to ask for a measurement during gassing. I will repeat the measurements after work at most.
    mczpski- what else should I measure? ps dad is 600 km away from me and he will not help much otherwise, residual informing him not to bother him - so without family missiles.
    during firing, nothing was ever blinking - read the lights, the controls were always on in line, always beeping - it has such a system that after half a turn of the key it beeps, after beeping, it only starts - and beeps.
    When firing the eyelashes / turns / catches the whole thing, and as long as I turn the key, there has never been a total "disaster". The moan of the electromagnet is totally unfamiliar to me - I have no idea what it sounds like.
    Like every car, it has the most powerful indicator that flashes - it is always on, even when it does not start.
    Now it turned out that the sister - the previous user unloaded it several times. it's only strange why has it worked flawlessly for the last year?
    ____________________________
    explanation:
    - After starting the car and driving about 10 km in medium traffic jams - 13.3V = I started samóch, drove a bit, drove home, stopped in the parking lot, did not turn off the engine - immediately after stopping, I took a measurement.
    -Car fired, without gassing, without turning anything on inside 13.96 V - I do not understand what should I explain? I turned off the airflow, the rear window, the light inside was off.
  • #17 16794771
    enhanced
    Help: 963
    Rate: 883
    Nieodzew was when you had to borrow electricity, wasn't it? Because otherwise why borrow?
    Are you sure 0.5mA? I don't know if it's even possible ;) Check because maybe 0.5A and that's a lot. Anyway, measure the voltage after a long stop (e.g. every 12H) as it will stay longer on the weekend and you will know a lot (without lighting / charging the battery). Check this amperage several times, because maybe some consumption comes out after some time - of course, everything with a closed car as if you were leaving it.
    The klems are sticking or something may not be connected?
    With a weak battery, the lights or the radio can and should go out when firing. Hence the question whether they are not fading. The LEDs from the alarm (because there is an alarm?) Let them flash, but those from the dashboard should dim (the radio is also turned on).
    The most interesting thing is that after borrowing electricity, it did not start at all - this something does not fit the falling battery, but something else.
  • #18 16794857
    tzok
    Help: 3176
    Rate: 6549
    There is a gas line under the hood ... you can add gas by pulling this line while "under the hood".
    kierbedz4
    Level 36  
    Help: 307
    Rate: 1008
    After 3 weeks of inactivity, the battery had the right to discharge and such a deep discharge leads to sulphation of the battery. If I leave the car for a longer time, I unscrew one of the clamps and then the battery rests and it is not possible to discharge it. You can also install a ground disconnect under the hood and disconnect it You can also install LED daytime running lights for the convenience of your battery, because when driving on dipped headlights on factory bulbs, the consumption current is about 10A with 2x 55W bulbs and without taking into account other current receivers installed in the car .
    robokop
    Help: 1763
    Rate: 6372
    Er, there. Probably no car is like that. The standard Vw had a charge around 14-14.2V and it was good. This is the upper limit of charging - will you finally acknowledge that if the voltage at the terminals while the engine is running is within the range of 13.9-14.4V, is the charging considered correct? Once again, someone will write nonsense that the alternator is to be replaced, exposing the user to unnecessary costs, I will personally charge him for it. Especially that the measurement was made with some kind of measuring device with unknown reliability of the indications. The battery is simply worn out - deep discharge during a 3-week stoppage simply finished it and that's it - you have to buy a new one, for the upcoming frost, it will be as found. For this, I suggest checking the condition and tension of the belt just in case.
    In addition, advanced users should note that the voltage regulator reference voltage is "measured" by it on the B + terminal of the alternator, not on the terminals - necessarily, with high currents, voltage drops on connections and wires will always be, and often the screw with an eyelet liked to rotate on the alternator.
  • #21 16796577
    zibi581
    Help: 36
    Rate: 174
    Girl, Martha, buy a new battery and after the trouble, the more you read pseudo-experts you won't be smarter, it's a waste of time.
  • #22 16796665
    freebsd
    Help: 766
    Rate: 2034
    Will the diagnosis with an electrician cost PLN 20? PLN 30? And it will take 5 minutes. I believe that before buying a battery for a few hundred zlotys, it is worth driving up and checking if the installation is OK. A car electrician will check the battery, alternator with a tester and inspect the cable fastening to the clamps, bodywork and alternator.
  • Alternator charging normally; battery likely discharged
    #23 16796901
    marta443
    Hits from today:
    Before firing 12.36V
    Immediately after starting 14.8V
    Upon arrival at 14.37v
    After arriving at the site and turning off the 12.83V engine, it was falling for about 10 minutes. It finally showed 12.33V and it probably fell somehow, but I didn't wait anymore.
    longer
    After work:
    Before starting at 15.00 measurement ----> 9.82 v and of course it did not start :( But it fired on jumper cables. After starting the engine, the voltmeter read 14.56v,
    After driving home and not turning off 14.56v, after turning off the engine, 12.7v dropped to 12.5v, I didn't wait any longer.
    so for me the alternator works? How do you think?
  • #24 16796931
    adamkowalski431
    Help: 7
    Rate: 72
    Battery to be replaced as has less than 12.55 cells are broken down and change the battery.
  • Need voltage measurements during startup attempts
    #25 16797207
    mczapski
    Level 40  
    Help: 468
    Rate: 1659
    So far, I do not have to withdraw anything I wrote. I did not write about the moans of the electromagnet, nor did I accuse my father, Marta43. Of course, I also didn't know about the distance between them, because from where. However, I wrote about the need to make measurements of electrical quantities (and maybe not only) and their interpretation. And as part of this advice, I am now repeating the need to measure the voltage at the installation (at different locations) during start-up attempts. For the battery in a long idle state as well as immediately after charging. And I can't help but do it with two people. The results of these measurements could determine the condition of the battery, although it is likely what has been suggested by long-standing advisers. And of course a visit to a car electrician would be advisable.
  • #26 16797233
    adamkowalski431
    Help: 7
    Rate: 72
    12.33 is a paddock. gets self-discharging, disconnect a good car for 5 hours, of course, charged and check it is 12.50 and below, chase a new one and that's it
  • #27 16797569
    kwok
    Level 40  
    Help: 496
    Rate: 1342
    Before installing a new one, you MUST check the power consumption because these 0.5mA are very weak, 20mA is a rarity - today usually around 50 .... If you can't measure correctly, ask an electrician.
  • #28 16797813
    vodiczka
    Help: 1185
    Rate: 4311
    You may not believe it, but I used the battery, which held 12.5V for a few hours after charging, for two years without any problems. Over 6 years in total.
    Helpful post?
    + [/ quote]
  • #29 16797822
    adamkowalski431
    Help: 7
    Rate: 72
    Okay, how do you explain the 9 volts with the hook
  • #30 16797824
    vodiczka
    Help: 1185
    Rate: 4311
    Batteries can be fickle :) Mine survived the winter of -15 ° C (worked flawlessly) and died in April of the following year.
    In my opinion, the battery is 95% and not an alternator. The easiest way (if possible) is to cross-test. Your battery for another car, a battery from another car for yours.
The discussion revolves around troubleshooting a 19-year-old Lanos sedan that failed to start after a three-week idle period. The owner experienced repeated starting issues, leading to the suspicion of either a battery or alternator problem. Responses suggest checking the battery voltage, with indications that the battery may be worn out due to deep discharge. Several users recommend measuring the voltage at various stages (before starting, after starting, and after driving) to assess the alternator's performance. The consensus leans towards replacing the battery, especially after it showed low voltage readings (below 12.5V) and failed to hold a charge. Users also advise checking electrical connections and potential parasitic drain on the battery. Ultimately, the owner confirmed purchasing a new battery, which resolved the starting issues.
TL;DR: Only 11.8 V open-circuit voltage leaves ~20 % charge, enough to stall most starters (Battery University 2023), and as one expert notes, "should be over 14 V while running" [Elektroda, adamkowalski431, post #16794032] Replace the sulfated 5-year-old battery; alternator readings are within spec.
Why it matters: A weak battery masks other faults and strands you at the worst moment.
• Healthy alternator output: 13.8–14.4 V at 1,500 rpm [Bosch, 2021] • Fully-charged 12 V lead-acid battery: 12.6–12.8 V open circuit (Battery University 2023) • Self-discharge: ~1 % per day at 25 °C; doubles every 10 °C rise (Battery University 2023) • Typical parasitic draw for 1999-2002 Lanos: 30–60 mA [Haynes, 2019] • Average costs (Poland): new 60 Ah battery 250–350 PLN; used alternator 150–300 PLN; swap labour 50 PLN [Elektroda, andrzej20001, post #16794048]
What alternator voltage should I see on a Daewoo Lanos?
Measure across the battery with engine at 1,500 rpm and lights off. You should read 13.8–14.4 V. Below 13.5 V indicates weak charging; above 15 V means the regulator overcharges [Bosch, 2021]. Marta’s 13.9 V idle reading is acceptable [Elektroda, marta443, post #16793998]
Why did the battery die after a 3-week parking break?
Lead-acid batteries self-discharge around 1 % daily at 25 °C; three weeks can drop a 60 Ah unit by 12–20 Ah, leaving <50 % state-of-charge (SOC) [Battery University 2023]. Deep discharge causes sulfation that permanently cuts capacity [DOE, 2020].
How can I separate battery faults from alternator faults in 5 minutes?
  1. Measure battery at rest: ≥12.6 V means charged. 2. Start engine; note voltage. Rise to 14 V shows alternator works. 3. Switch headlights and blower on; voltage must stay ≥13.8 V. Drop to 12 V points to alternator or cabling issue [Elektroda, tzok, post #16794489]
My meter showed 9.8 V during a start attempt—what does that mean?
Cranking voltage below 10 V signals at least one shorted cell or heavy sulfation. A healthy 12 V battery should stay above 10.5 V under starter load [SAE J537]. Replace the battery; further charging won’t restore lost capacity [Elektroda, marta443, post #16796901]
What standby (parasitic) current is acceptable on a Lanos?
30–60 mA is typical; values under 80 mA rarely drain a 60 Ah battery in under two weeks [Haynes, 2019]. Marta’s measurement of 0.5 mA was likely a meter range error; re-check using the 10 A port and wait 5 minutes for modules to sleep [Elektroda, enhanced, post #16794771]
Can loose clamps really stop the engine from starting?
Yes. High-resistance clamps drop voltage during starter peaks (150–200 A). Even 0.05 Ω can rob 10 V (V=IR), leaving electronics dead. Cleaning and tightening restored Marta’s starts for a week [Elektroda, marta443, post #16793998]
Is 14.8 V right after cold start harmful?
Momentary 14.8 V is normal on cold mornings; regulators lower to <14.4 V as the alternator warms. Sustained >15 V boils electrolyte and can fry ECUs—an edge-case to monitor with a voltmeter [Delphi, 2022].
How long should I charge a 60 Ah battery with a 6 A charger?
At 80 % efficiency, you need about 11 hours to move the 40 Ah required from 0 % to full SOC: (60 Ah ×100 %) ÷ (6 A ×0.8) ≈ 12.5 h. Stop when current falls below 1 A or voltage reaches 14.4 V (constant voltage phase) [CTEK, 2021].
What does labour and parts cost to swap an alternator on a Lanos in Poland?
Used alternator: 150–300 PLN; new aftermarket: 400–600 PLN. Average labour: 50–80 PLN because it’s a 30-minute job with basic tools [Elektroda, andrzej20001, post #16794048]
How do I measure parasitic draw with a multimeter?
  1. Turn ignition off; close doors. 2. Set meter to 10 A; place in series between battery positive post and cable. 3. Wait 5 minutes for control units to sleep, then read amperage. Values above 80 mA mean a "current thief" [Elektroda, enhanced, post #16794066]
Could a failing diode in the alternator mimic a bad battery?
Yes. A shorted diode reduces charging current and can leak reverse current overnight, draining 0.5–2 A—enough to flatten a 60 Ah battery in 1–2 days. It also produces AC ripple that ages batteries faster [Bosch, 2021].
When is it smarter to scrap than repair a 19-year-old Lanos?
Add expected costs: battery 300 PLN, tyres 900 PLN, suspension 800 PLN. If the sum exceeds 60 % of the car’s market value (~2,500 PLN) it is economically wiser to sell or scrap [Polish Auto-Trader, 2023].
